Clutch Noise Or ... ?
6 replies to this topic
#1 pavel79
pavel79
  • 85 posts
Posted 27 January 2020 - 12:50 pm
Hi everyone!
Give me please advice :-)
I have a knocking noise from my 900 engine. From the clutch cover or from transmission. I can hear it from both sides of the engine.
The knocking becomes louder after turning the throttle but almost disappears when I press the clutch lever.
What the reason of this noise? Clutch basket?
You are welcome to hear it here
https://youtu.be/g9Zaz7D-aV8
https://youtu.be/AR23jxG5_K0
Thank you in advance :-)
#2 fixitsan
  • 4,676 posts
Posted 27 January 2020 - 02:28 pm
Yes sounds like the clutch to me. Normally it sounds worse if the throttle bodies are a bit out of balance, or there is another fault causing slightly rough running, which causes the basket to clatter about more than normal
#3 pavel79
pavel79
  • 85 posts
Posted 27 January 2020 - 03:17 pm
Thanks!
I checked throttle bodies balans last month and it is OK or very close to OK :-)
My friend did it by DIY digital synchronizer and I don't know what is the measurement error of his device.
Edited by pavel79, 27 January 2020 - 04:11 pm.
#4 leehenty
  • 5,091 posts
Posted 27 January 2020 - 07:45 pm
Lumpy running also makes noise from backlash in the gears. Pulling in clutch makes this quieter as only oil drag is pulling the gears round. Assuming the clutch isn't dragging. Your bikes sounds ok.
#5 pavel79
pavel79
  • 85 posts
Posted 28 January 2020 - 05:04 am
:signthankspin:
#6 TKH
Posted 28 January 2020 - 06:02 pm
Was it me or did the throttle have some lag in it?
#7 pavel79
pavel79
  • 85 posts
Posted 28 January 2020 - 07:30 pm
This is quite likely. Free play of right grip a little bigger than standart. I am going to adjust it soon.
