Posted 15 July 2020 - 06:10 pm
Well my brother lives in Snodland he is very good on bikes, he is in the LAS and sometimes works on the historical fleet. The only thing he has no kit for is doing the valve shims on TDM's, but I have a shim kit, so I could visit down there and use his garage if this needs to be done.
Generally I ask those who we help out become supporting members in return, it only costs a fiver.
Edited by leehenty, 15 July 2020 - 06:19 pm.
