Is Electric Fuel Pump Causing Problems
15 replies to this topic
#1 madmopedracer
madmopedracer
  • 473 posts
Posted 17 August 2018 - 09:53 pm
Fitted a low pressure facit fuel pump used to get 180 miles to the tank now getting 100 miles time to look for a replacement vacuum one
#2 wicklamulla
Posted 17 August 2018 - 10:47 pm
did you notice the increase in fuel consumption immediately after fitting the electric pump ?
#3 madmopedracer
madmopedracer
  • 473 posts
Posted 18 August 2018 - 08:11 am
Thought it was another problem missfire and cutting out on one cylinder fixed that needed new RR I don't notice fuel consumption on short journeys this is the first long run in a while
#4 TKH
Posted 18 August 2018 - 03:48 pm
Fuel leak anywhere? That's and awful lot of disappearing fuel.
#5 madmopedracer
madmopedracer
  • 473 posts
Posted 18 August 2018 - 03:53 pm
just back from the lakes weekend aborted as someone took my mate out on his 900 om motorway nr oxford
just bruised ribs think the bike is not too bad could have been worse
weather was awful if i get time tomorrow a good clean and ill start investigation as electricity leak is sorted
so one thing ruled out
#6 TKH
Posted 18 August 2018 - 07:21 pm
All the best to your mate and I hope he's well soon.
#7 Sidarta
Sidarta
  • 845 posts
Posted 18 August 2018 - 09:53 pm
Hi madmopedracer!
Due to the translation, I did not quite understand the relation: how many miles x how many liters. :sorry:
Did you check the oil level? Depending on the pump (pressure ??), height of the buoys and condition of the sealing of the needles of the buoys, the excess may have gone into the engine oil. I find it difficult, because you talk about long journey, therefore greater engine rotation.
However it is worth checking, by removing the top cover of the oil compartment and sniffing.
If smell gasoline; Bingo.
But, no smell of gas .... :hide:
Cheers!
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#8 Bjørge
  • 1,791 posts
Posted 19 August 2018 - 06:46 am
You could check out the emulsion tubes for wear, poor mileage is a well known side effect of worn ones....
#9 madmopedracer
madmopedracer
  • 473 posts
Posted 19 August 2018 - 11:53 am
i have some time off work at the end of the month so will have time to check it out.
this has been a sudden change in fuel consumption not a gradual decrease
usually i get about 55mpg now around 35 to 40 mpg
#10 dablik
  • 10,747 posts
Posted 19 August 2018 - 12:08 pm
Apart from a leak dont know what else except emulsion tubes could cause it, doubt the pump is at fault though, should either work or not !!
#11 Apache
Apache
  • 553 posts
Posted 19 August 2018 - 01:38 pm
100 miles a tank or to reserve tap switchover ? Tap or tap filter blockage causing switchover too early ? Just a thought....
#12 Studley Ramrod
  • 19,213 posts
Posted 19 August 2018 - 03:42 pm
Is it possible you got yer calcs wrong ?  Maybe thought you'd filled it but hadn't, or summat similar.
I know a faulty coil can increase consumption, as can a damp HT lead.
#13 madmopedracer
madmopedracer
  • 473 posts
Posted 19 August 2018 - 03:46 pm
to reserve
it may be coincidence that it has only come to notice since changing the pump
#14 Bjørge
  • 1,791 posts
Posted 19 August 2018 - 09:34 pm
The other possibility may be stuck choke plungers - if so, they would show symptoms of fat mixture: a) Easy cold start with no choke and b) poor running when hot / black deposits in exhaust outlet tube / maybe some black smoke
#15 TKH
Posted 20 August 2018 - 11:04 am
Choke sticking or the bike overfueling can often be picked up with someone following behind, as well as black deposits on spark plugs, etc.
#16 madmopedracer
madmopedracer
  • 473 posts
Posted 20 August 2018 - 03:41 pm
100 miles before going to reserve had to top it up 4 times on trip to penrith and back
will look at all the suggestions when I next get a chance to look at it
