All About Trx !
17 replies to this topic
#1 wicklamulla
Posted 11 December 2019 - 03:30 pm
29312967_10157196730517067_7253784648787
Head returned from having the seats re cut and std MLS head gasket cleaned and re coated with Hylomar blue.
This will be the 4 th time I’ve used the same head gasket.
No issues with leaks at all the last 3 times I re coated it even with 12.5:1 compression.
All clearances set once again and back on the bike.
Tomorrow’s task is to fit the FCR’s and exhaust and go for a spin through the countryside.
This chap doesn't mess about.  Tink he has an ultra rare Over Racing 6 speed box too as well as udder exotic Over bits and pieces.
#2 leehenty
  • 5,088 posts
Posted 11 December 2019 - 05:27 pm
Ooh they do look nice, Yamaha's idea of a Ducati. Go quite well too.
#3 wicklamulla
Posted 11 December 2019 - 06:14 pm
Lee i remember they used to make feck all used and some people bought cheap speed as a result,  they are now gone up in value.
#4 dandywarhol
Posted 13 December 2019 - 11:13 am
Sold mine last year - prices steadily rising for clean stock ones
#5 Quartermaster
Quartermaster
  • 927 posts
Posted 14 December 2019 - 10:09 am
I loved my TRX.
  • Attached File  trx.jpg   134.07KB   1 downloads
#6 Quartermaster
Quartermaster
  • 927 posts
Posted 14 December 2019 - 12:55 pm
On YouTube
#7 Favs
  • 4,395 posts
Posted 14 December 2019 - 06:06 pm
Black  - like the one Splodge has in his collection
#8 dandywarhol
Posted 14 December 2019 - 08:46 pm
I loved playing with the big bhoys on my TRX  :pimp:  https://www.youtube....h?v=CKnD1b14f7g
and some drivel from Hammond..................... https://www.youtube....h?v=AYDK5FciNMI
Edited by dandywarhol, 14 December 2019 - 09:14 pm.
#9 Favs
  • 4,395 posts
Posted 14 December 2019 - 10:46 pm
+1 on my Saturno. Buffalo girls.
#10 dandywarhol
Posted 14 December 2019 - 10:51 pm
Around the outside............................... haaaaaaa
#11 leehenty
  • 5,088 posts
Posted 17 December 2019 - 08:55 pm
On YouTube
At 0.58 minus a point for rusty head on front wheel spindle.  :punishment:  otherwise very super tricked.
#12 dandywarhol
Posted 17 December 2019 - 10:53 pm
That's Cobbas - don't like the sprocket cover - the rest is super trick, as is the big bore engine, FCRs, Over gearbox, etc.................................
#13 dablik
  • 10,754 posts
Posted 18 December 2019 - 09:38 am
Ang on, re-used the MLS head gasket 4 times with Hylomar with no leaks.........i seem to remember it was always advised on ere to renew head gasket any time the head came off because they get a good squash when torqued up and were throw away, and they aint cheap either...
#14 dandywarhol
Posted 18 December 2019 - 11:37 am
I seem to recall his is a single layer copper gasket. That engine has had more time spent on it than Mr Yamaha spent designing it..........................
#15 dablik
  • 10,754 posts
Posted 18 December 2019 - 08:12 pm
So assume he probably anneals it as well  before re-use then, he called it an MLS gasket which is multi layered though !!
#16 wicklamulla
Posted 18 December 2019 - 10:26 pm
Al did he (Hank) used to frequent this forum a lot a few years ago?
#17 dandywarhol
Posted 19 December 2019 - 12:09 am
Don't know then. Best to ask the man directly
#18 dablik
  • 10,754 posts
Posted 19 December 2019 - 03:20 pm
:good:
