to the madhouse.
Rules of ownership (3vd & 4tx)
One - Check the oil! (3vd and 4tx engines use it up and react very badly to not having enough).
Two - See above
These engines burn up to a litre per 1000Km, so it might be that your seeing in the pipes.
New emulsion tubes probably wouldn't hurt it any after 32K miles, it'll give you a chance to sort the carbs out properly at the same time. I ran my 4tx a bit rich and that seems to have killed off the stutter you mention.
I used to get up in the high 50+MPG when I'd sorted my Mk2 which worked out to 160 miles to reserve (ish) but yours has a different capacity tank I believe, so no help there.
There's some good advice in the knowledge base on the emulsion tubes subject, it is a pain but if I can do it anyone can. Also there are people here who will work for cake (or at least stand around and watch you do it). Where are you located?
I'm not sure why someone would put a silencer on the wrong way round but I can't imagine it would do any good.
Would it make it louder?
Oh and we like pictures.
Have the valve clearances been done? Due at around 28k as I recall.
There will be others along in a bit with more 3vd time to help you along.
Mick
