Tdm Rotor Bolt Rh Or Lh Thread?
26 replies to this topic
#1 Phracker
Phracker
  • 19 posts
Posted 08 April 2019 - 08:11 pm
Stripping down my 92 850 3VD and stuck on trying to free the bolt holding the rotor on. It should break free at 100 ft/lbs, but the thing is making me nervous.
Shop manual says nothing about it being a LH thread, but better to ask then do damage.
#2 dapleb
  • 18,104 posts
Posted 08 April 2019 - 09:09 pm
Normal thread. An excellent fitting bit and a little heat. Good luck!
#3 g650xtdm
g650xtdm
  • 295 posts
Posted 09 April 2019 - 03:52 am
As I recall, when I replaced my front rotors I had to use vise grips on a couple of them to get them started.  That was after spraying them liberally with penetrating oil.  I was replacing the bolts anyway, so I didn't mind buggering them up.  Grabbing them around the circumference with vise grips gave me the extra torque I needed to brake them free.  I good tap with a hammer may help too, provided you can do it without bending anything,
#4 Studley Ramrod
  • 19,202 posts
Posted 09 April 2019 - 09:05 am
You merkins with yer rotor talk, very confuzing. :lol:  Think Phracker is talking alternator rotor bolt.
#5 dapleb
  • 18,104 posts
Posted 09 April 2019 - 10:22 am
Ahhh mix a ma rotors
#6 Nig
Nig
  • 217 posts
Posted 09 April 2019 - 03:17 pm
That's what makes rabbits grow 3 eyes innit!
#7 Phracker
Phracker
  • 19 posts
Posted 09 April 2019 - 05:09 pm
I apologize, this is the stator rotor bolt that holds it onto the crank.
It was fun to google because all I was seeing was brake parts.
Will take a crack at it this weekend.
#8 g650xtdm
g650xtdm
  • 295 posts
Posted 10 April 2019 - 01:00 am
It would help if you Brits would learn to speak English!  That goes for Canadians too!
#9 Rallyist
  • 3,250 posts
Posted 10 April 2019 - 07:51 am
That's rich coming from that side of the pond considering what you did to the proper English language. :hide:
#10 MickC
MickC
  • 404 posts
Posted 10 April 2019 - 09:11 am
You dont say why you are srtipping your engine so if this helps I undid my rotor bolt but could not get the rotor itself off so I left it on split the cases (MK2) and took it down to my freindly garage to pull off for me so If you are stuck leave it on and get a garage or even a tyre fitter to undo the bolt with their air rachet hammer thingy but if you cant then get the rotor off you will need a garage.
If you ar not doing anything with the crank or rotor leave it alone,no need to take it off
#11 divvxj
divvxj
  • 1,296 posts
Posted 10 April 2019 - 05:26 pm
tire??
#12 fixitsan
  • 4,667 posts
Posted 10 April 2019 - 05:29 pm
I did the same, my puller couldn't hack it. The puller at the garage bent and cracked but eventually came off. It cost them more for the replacement puller than the £15 I paid !
#13 dapleb
  • 18,104 posts
Posted 10 April 2019 - 06:18 pm
The bolt is the easy bit, once thats oot the way a puller will get it off but you may poo yer pants when it finally gives in as they often make one helluva bang.
#14 fixitsan
  • 4,667 posts
Posted 10 April 2019 - 07:45 pm
 The stator is the collection of windings inside the cover and the rotor is the part with the magnets. The stator is stationary and the rotor rotates (just following the speekin propah inglish theme)
Cockford Olly ;)
#15 MickC
MickC
  • 404 posts
Posted 10 April 2019 - 08:03 pm
Mine cost me a pack of sausages----we do are own pork :badgerrock:
#16 Phracker
Phracker
  • 19 posts
Posted 10 April 2019 - 08:13 pm
Cockford Olly ;)
Yeah, it was a haste reply. Should have been a touch more clear on my description.
Not a bad idea at all to work around it. If I can, then that saves me the grief of trying to pull the bloody thing off.
Basically, motor got pulled after a pile of issues started to stack up.
1) Valve seals leaking since the day I bought it (8+ years ago and 50,000km)
2) Output shaft threads are done. Last guy (Always their fault really) wasn’t kind to the bike and I think the nut spun off once on him. I got lucky on the first sprocket change, but chased the threads with a die I had and used a little blue threadlock. 2nd time I switched it out I got that 6th sense that the threads were stripping at 20ft/lbs when torqueing up. I spun it off and put on a thin layer of JB weld epoxy and then snugged it up as best I could.
*Bought a spare 3 years back and have just been waiting for the right time to swap it.
3) 3rd gear has lost the will to do any work. Can gingerly get it to shift, but will pop out if under high load or I rev over 3000. Not sure what I will do here, first I need to see what is causing the issue.
Also have found some other concerns, but I will wait and see what the state of the engine is first and work backwards.
Bottom line is I need to get into the transmission to swap the output shaft and troubleshoot the 3rd gear issue.
Hey now, let's just get a pint and try to find a sport we can all quietly watch on the telly. Maybe get lucky and split a plate of food.
#17 fixitsan
  • 4,667 posts
Posted 11 April 2019 - 03:39 pm
There was one rotor I couldn't get off the crankshaft and took the risk of rebuilding with the rotor still attached to the crank out of the engine cases, which had to be split anyway. I took the chance with the crankcase oil seal behind the rotor, that I would be able to get it to reseat in the cases without it leaking. I think the 850 crank oil seal is in two halves, seated in the cases, so if that's the case you should be fine to leave the rotor on the crank.
When it comes to setting everything back up, from memory you need to use the crank/rotor slotted keyway as a reference mark to position the crank in roughly the correct alignment with the other rotating parts, but it will all become obvious as you dismantle it.
#18 dablik
  • 10,735 posts
Posted 12 April 2019 - 03:59 pm
Daps what's prefered type of puller to get the rotor off ! 3 legged variety (ya know how long) or a puller wot fits in the rotor bolt hole ?
Might be a job on :huh:
Edited by dablik, 12 April 2019 - 04:00 pm.
#19 dapleb
  • 18,104 posts
Posted 12 April 2019 - 05:23 pm
Tree legged but watch yer hands fizzog and any other of your handsome bits and wear some old unwanted shreddies cous there is a sudden and dramatic kaabooom when they finally go.
Summat through the rotor might be more elegant if you can get it to work.
I bought a harmonic balancer remover recently and wondered if that might be a useful remover of rotors.
#20 dablik
  • 10,735 posts
Posted 12 April 2019 - 05:51 pm
Yep just been looking at the Harmonic balancer/puller thingy which might be a good solution, but needs to be long enough across the rotor, any idea of the width if ya grey cells can remember, mind aint you got one with a shrub innit in the garden :)
Might ask me friendly mechanic if he fancies wuppitin it off maybe..
