* * - - - 1 votes
Front Break Bleeding
7 replies to this topic
#1 MikeD
MikeD
  • 12 posts
Posted 17 April 2019 - 06:59 pm
Good evening!
Working my way round my '9 I found the rear break fluid was like dark syrup and the fronts were only slightly better.
Cleaned out the rears and passed a few master cylinders of fresh oil through and all is great. The fronts were also really bunged up around the pistons, so I gave them a clean too. Using a syringe i pushed new fluid up the lines and it all seems OK. However I can't seem to bleed the bloody things. I have a pipe and one way valve fitted and working on each side i have been extracting bubbles, however i never seem to be able to reach a firm lever - its very spongy, although the front brake is binding.
Any thoughts, hints or tips?
Cheers! Mike
#2 Bigmatt
Bigmatt
  • 48 posts
Posted 17 April 2019 - 07:26 pm
If you are still getting bubbles then keep on bleeding until no more bubbles appear. Then tie your brake lever to the handlebars so it is compressed. Let it sit overnight. It worked last time I changed fluids on my TDM and is the only way I can get the front brake on my Harley to feel firm.
#3 MikeD
MikeD
  • 12 posts
Posted 17 April 2019 - 07:35 pm
Bigmatt, thank you. Will  give that a shot! Cheers, Mike
#4 dablik
  • 10,757 posts
Posted 17 April 2019 - 08:30 pm
You should have most of the air out if you've reversed filled with a syringe, like you i normally uses a pipe with one way valve to get the lever firm, can be a bit of a fiddle on the 9r,you could crack the banjo at the MC as well just slightly while pumping to remove air, best is to fit a double banjo at the MC as it resolves the issue pretty much.
#5 MikeD
MikeD
  • 12 posts
Posted 17 April 2019 - 08:39 pm
Thanks both, I have tied the lever up and will see what the morning brings. If still no joy I will try as you suggest, cheers
#6 Johnners
Johnners
  • 120 posts
Posted 18 April 2019 - 09:16 am
One other thing worth trying, when bleeding, rotate the bars make sure the master cylinder and resevoir are higher than the banjo connection, otherwise bubbles can get stuck there resulting in squishy lever.
#7 muddy
  • 2,973 posts
Posted 18 April 2019 - 03:27 pm
+1 Reverse filling seems to be the best way to do the blue spots.
#8 MipeTDM
MipeTDM
  • 92 posts
Posted 25 April 2019 - 12:54 pm
Hi, you can also try it like this, works especially well with a 2-line setup to the master cylinder. I have blue spot calipers as well, see my video:
https://mpesgens.hom...9_150835039.mp4
Pump first, to get some pressure, then gently press on the brake lever to release the pressure.
