Non Starter Please Help.
Posted 01 June 2015 - 05:21 pm
Well it's been a whilst since I've had a problem with the beast but this morning she did not want to start and she's popping up with error 11 manual says it's the cylinder identification sensor can anyone tell me do I just need to replace the sensor or is it going to be something else please help me thanks. TDM 900 2007
Posted 01 June 2015 - 05:33 pm
Does it even try to start, or are you just getting a click when you press the go button?
Can't remember if I've seen Err.11 before, but I'd suggest getting the battery on the charger overnight to ensure it's got all the beans.
If you still have problems after that then start looking into the less common problems.
A good percentage of 900 starting issues are due to its sensitivity to battery voltage.
Posted 01 June 2015 - 06:15 pm
Posted 01 June 2015 - 07:02 pm
That's the 3rd 900 I know of now with this problem, assuming that is the issue !!
Posted 01 June 2015 - 07:26 pm
Posted 01 June 2015 - 09:18 pm
If you take off the plastic outer cover for access to the sprocket you will find another cover take it off and the speed sensor is inside, unless you have ABS, then you wont have one i believe.
Edit.......will drag the manual out tomorrow for a look as it was a good few years ago, in the mean time this will give you an idea as cant seem to find them on the parts fiche.
If you take off the sprocket cover and then the shift shaft cover, the sensor should be inside me thinks.
Edited by dablik, 01 June 2015 - 09:49 pm.
Posted 02 June 2015 - 07:03 am
Posted 02 June 2015 - 09:38 am
I've got a set of the workshop manuals stashed here if it's any help http://www.fieldscie...co.uk/link/TDM/
Posted 02 June 2015 - 01:53 pm
Just had a look at Chris's link above, choose the manual for 2002 and under the engine section paragraph 5-7 will show where the cylinder identification sensor is located, for the speed sensor which it does not show (least i cant find it) go to paragraph 5-51 that will at least show you where the speed sensor rotor is, been awhile since i was in there but sure you'll find it Reaper
Also if i recall the sensor swap is mentioned on the jbx site, need a link anyone please, not getting a hit, or better where's a Frenchman when ya need him
This is exactly what aircooled and i did with my bike to check the cylinder id sensor years ago.
Posted 02 June 2015 - 02:40 pm
Posted 02 June 2015 - 02:49 pm
Check your HT leads and Coils
Posted 02 June 2015 - 03:53 pm
Posted 02 June 2015 - 06:13 pm
HT leads won't show on the diag, they leak and lose there power by arching against the frame and cylinder head.
Posted 02 June 2015 - 06:34 pm
#16
Posted 02 June 2015 - 07:42 pm
Take the side panels off start the bike and chuck a bit of water over the coils, well not a bucket full spray a little water or flick it on with your hand and you will see pretty colours, have a look on the frame as often theirs a tell tale sign, black scorch marks.
Read this and a search will bring up plenty more posts.
#17
Posted 03 June 2015 - 04:06 am
#18
Posted 03 June 2015 - 05:25 am
Didn't bother checking mine, they got the self amalgamating tape treatment anyway. It's a common failing so def worth doing.
Posted 03 June 2015 - 08:38 am
For the cost of the SA tape, and the time it takes just tape 'em up
#20
Posted 03 June 2015 - 06:38 pm
