Headlight Adjustment Niner ?
Posted 21 May 2011 - 09:02 pm
Ok, been with my niner for half a year now. Liking it a fair bit... So much in fact, that I almost have skipped the thought of upgrading it to a F800/1200 GS.
There is alot to like in the TDM, but one thing really bugs me... It is quite sensitive to weight-changes, that is, I ride alot with the misses on the pillion, and also with shifting luggage weight in my panniers. I will try to deal with the difference in handling by upgrading to Hyperpro suspension all over (also making it ALOT easier to access spring preload !). However, car/fellow motorcyclists continuously falshses me because my headlight beam is adjusted to signal UFO's. and I just can't seem to get the damn thing to good base setting...
What do you guys do ?. I tried adjusting with a Phillips screwdriver, but it's really hard to 'feel' the adjuster in the headlight... I would think it's made of plastic ?!. Also, I don't seem to have a horizontal adjuster on me niner ?.
Posted 22 May 2011 - 08:05 am
I usually carry a screwdriver to adjust and have learned how many turns it needs. One small sticker with up and down directions stuck under the front helps.
Edited by leehenty, 22 May 2011 - 08:06 am.
Posted 22 May 2011 - 09:04 pm
Upgrade to an F800
Posted 23 May 2011 - 07:34 am
Well, I was inclined to try it out, but after that remark I'm not so sure ....
Posted 22 January 2016 - 09:47 pm
How do you adjust vertical alignment? I need to get mine up higher
Posted 22 January 2016 - 10:15 pm
"I need to get mine up higher" - as the bishop said to the actress.........
Here's the appropriate bit from a manual. Do you not have one? They are available on JBX's site IIRC. Check you get the correct date version.
delete.pdf 180.5KB 27 downloads
HTH
Edited by steve27bha, 22 January 2016 - 10:27 pm.
Posted 22 January 2016 - 10:40 pm
Thanks Steve....RTFM I guess. I just couldn't find it ...... so said the Bishop's mistress
