Can I Do This?
4 replies to this topic
#1 Dazmk2850
Dazmk2850
  • 13 posts
Posted 26 October 2020 - 03:48 pm
hi guys and gals
I have recently ordered a cheapo pair of led spot lights. Can i wire these directly into my full beam so they come on together?
#2 ChrisG
  • 8,276 posts
Posted 26 October 2020 - 05:10 pm
You should be fine as LED's are generally fairly low power.  A better solution though would be to use an automotive relay, use the headlight as the switch signal (pin 85 or 86 with the other one earthed), power pin 30 from the battery via an inline fuse, and connect the positive side of your lights to pin 87.  The relay uses a miniscule amount of power from the headlight connection to hold the switch closed and all the power comes straight from the battery,
#3 fixitsan
  • 4,671 posts
Posted 26 October 2020 - 06:41 pm
Do you have a link to them, one which possibly shows the specs including the current draw ?
#4 Dazmk2850
Dazmk2850
  • 13 posts
Posted 28 October 2020 - 11:23 am
I ended up feeding into the full beam power and i can now see at night
#5 qual
qual
  • 20 posts
Posted 31 October 2020 - 07:34 am
Can u pop a link to the lights you got? I too would like some of that night time vision you talk of!
