900 Battery Removal
900 battery change removal
27 replies to this topic
#1 TDMerlin
TDMerlin
  • 2 posts
Posted 14 April 2018 - 11:54 am
If tried using logic. I've search the web. I've searched here, but how do i get the battery out of my 02 900 so I can replace it?
#2 Joe90
Joe90
  • 105 posts
Posted 14 April 2018 - 12:17 pm
It is a bit tricky but I used a bungee cord with the hooks through the battery terminals on my 900 of the same year.Just make sure the hooks are plastic covered (insulated)I've done this several times.
Alternately use some thin nylon cord tied through the terminals
I hope this helps
#3 dablik
  • 10,753 posts
Posted 14 April 2018 - 03:35 pm
And then wrap some tape around ya new battery with a handle onnit for future pulling out.
#4 TDM4ever
TDM4ever
  • 302 posts
Posted 14 April 2018 - 08:10 pm
Apparently, they improved that on the 2007+ models, because my battery just lifts out without any problems.
Edited by TDM4ever, 16 April 2018 - 01:30 pm.
#5 JBX
Posted 17 April 2018 - 11:27 pm
No change on that point on the 2007+ models, it's just you are better trained after some time...  ;)
#6 TDM4ever
TDM4ever
  • 302 posts
Posted 18 April 2018 - 07:30 am
Not sure you are right on that one?
You just unhook the rubber strap reach down and lift out the battery. No need for hooks, tape and taking off the rear brake cylinder, as what seems to be suggested by all pre-2007 owners.
#7 JBX
Posted 18 April 2018 - 11:51 am
On my 2002 9er I just unhook the rubber strap and lift out the battery.
No need for any tools.
The rear brake fluid tank is not present on non-ABS models.
The rear brake fluid tank support is the same part (same number, no revision) on all ABS models (2B0).
#8 TDM4ever
TDM4ever
  • 302 posts
Posted 18 April 2018 - 11:55 am
OK, so why all the concerns and various "tricks" from other 9'er owners??
If it is the same on all 9's there is absolutely no need for any "tricks" or special tools. It is very obvious that you can easily lift it out, so it is very strange that they can't see that?
Anyway, keep riding  ;)
#9 Joe90
Joe90
  • 105 posts
Posted 18 April 2018 - 01:02 pm
Why all the debate?
If you can remove the battery without using some simple aid then good on you.
I just found that I could not get enough of a handhold on mine.
The original questioner obviously needed something more hence the suggestions.
#10 JBX
Posted 18 April 2018 - 01:37 pm
There are different level of tricks :
1 - those that you must use to actually do the job.
2 - those that improve your comfort ie make things easier or faster.
3 - those that make their author happy.
Tricks on this page are from level #2.
Just joking... ;)
#11 Joe90
Joe90
  • 105 posts
Posted 18 April 2018 - 01:49 pm
A better solution -You can pop over to mine and remove the battery for me next time it needs to be liberated!
#12 Nog
Nog
  • 514 posts
Posted 18 April 2018 - 02:04 pm
Just noticed they've moved the rear brake reservoir to a sensible place too, they're a right pain to fill on the old models.
#13 chrisr
  • 1,746 posts
Posted 18 April 2018 - 04:51 pm
I think that may be an abs version
#14 TDM4ever
TDM4ever
  • 302 posts
Posted 18 April 2018 - 07:27 pm
That´s correct.
#15 Robodene
Robodene
    Robodene
  • 1,514 posts
Posted 18 April 2018 - 08:37 pm
If I remember rightly, I used coat hanger wire to it lift.
#16 JBX
Posted 19 April 2018 - 12:00 am
Don't stress too much about this, in 16 years of TDM900 ownership, I removed the battery once when replacing it for a Yuasa, this was 7 years ago !
#17 TDM4ever
TDM4ever
  • 302 posts
Posted 19 April 2018 - 07:10 am
True, no need to stress  :)
However, I (and probably many others) take the battery out every winter and put it on a maintenance charger.
#18 Nog
Nog
  • 514 posts
Posted 19 April 2018 - 07:37 am
Well I wouldn't use another Motobat as in the above picture.  I had one on my Fazer and it barely made it through a year.  Had been looked after like any of my bikes and the terminals failed and leaked acid.  Have heard of others having similar experiences.  I always go Yuasa now, worth every penny for the length of time you get out of them.
#19 Riggers
Riggers
  • 531 posts
Posted 19 April 2018 - 08:07 am
I screw two longer bolts into the terminals and use them as handles. Works for me.....
Riggers.
#20 Joe90
Joe90
  • 105 posts
Posted 19 April 2018 - 08:11 am
Yes, Yuasa every time.
I only changed my original Yuasa '02 battery last year
I'd still be using it if I hadn't left the bike standing for too long which was purely a fault of mine.
Phenomenal piece of kit,just like the rest of the bike.
