92 Tdm Electrical Problem
6 replies to this topic
#1 bat
bat
  • 13 posts
Posted 06 March 2019 - 02:05 pm
Bought a 92 TDM that had a electric fuel pump, which I replaced and you guys helped me get fuel lines hooked up right. Now after all that done, got a new battery and switched the key on and nothing, no lights nothing. I get power to ignition switch plug but nothing beyond that. What is wrong ?
#2 fixitsan
  • 4,676 posts
Posted 06 March 2019 - 02:18 pm
Bad connector or failed switch by the sounds of it. It's really just a case of using your testmeter with pin probes and tracing along the circuit to where the power stops.
If you have power on one side of the plug but not the terminal on the other then you could look at the crimps of the spade terminals in the plug/socket
#3 wicklamulla
Posted 06 March 2019 - 10:32 pm
wonder if it's blown a fuse due to you working on the wiring when ya removed the electric fuel pump?
#4 Studley Ramrod
  • 19,214 posts
Posted 07 March 2019 - 09:35 am
:wifgeni:
Yep, I was gonna say check yer fuses first.
#5 mh1848
mh1848
  • 507 posts
Posted 07 March 2019 - 04:20 pm
on this age of bike the wiring can get pretty corroded and connections a bit ropey as i know from personal experience - breaks in connector blocks giving intermittent faults - especially those to relays on starting circuit. You might also need to check carefully with meter, as Fixitsan notes  all connections to fuse box and relays - I and i am sure others with Mk1s have had to renew complete fuse-box
#6 dablik
  • 10,757 posts
Posted 07 March 2019 - 06:41 pm
Yup i agree, unwrapped mine and found a number of issues, some wires corroded and repalced a cupla connectors, removed all cables from the fuse box to clean up.
#7 TKH
Posted 07 March 2019 - 10:34 pm
Take it that you haven't moved the disable/kill switch on the bars? I did it one and spent ages trying to find out what was wrong.
