Any Tips On Spraying A Rack?
17 replies to this topic
#1 skedaddle
skedaddle
  • 52 posts
Posted 11 March 2019 - 01:17 pm
Anyone ever tried spray painting a luggage rack? The one that came with the bike is fairly sturdy but looks crap. Basically would cans of paint do and what kind of prep.
#2 JMC
JMC
  • 257 posts
Posted 11 March 2019 - 02:30 pm
Sand it, few coats of primer and several light coats of paint should do it but if you want a proper job get it powder coated
Hunter S. Thompson.
#3 skedaddle
skedaddle
  • 52 posts
Posted 11 March 2019 - 03:31 pm
Nice one, not sure how much I'd be willing to spend on doing up a luggage rack, time and effort is OK but might not be worth a powder coat. Will give it a go anyway I'd say.
#4 TKH
Posted 11 March 2019 - 04:20 pm
You could use something like Hammerite I think that kind of paint is a bit dearer than most ordinary paints. If you prep properly it should give a more durable finish.
This reminds me I must do my rack......
#5 divvxj
divvxj
  • 1,296 posts
Posted 11 March 2019 - 04:44 pm
+1 , neighbour has a sand blasting cabinet , primer then several coats
#6 skedaddle
skedaddle
  • 52 posts
Posted 11 March 2019 - 05:47 pm
Cheers, I have something similar i used on a car for painting over rust. Might try and find a matt black and give it a go.
#7 skedaddle
skedaddle
  • 52 posts
Posted 11 March 2019 - 05:53 pm
Will try spraying it i think. Dont have a sand blaster handy, might compromise and try and find some environment-destroying chemicals to help take the paint off and do a proper spray job from scratch.
#8 Gdogg
Gdogg
  • 1,163 posts
Posted 11 March 2019 - 06:12 pm
Hi Skedaddle,
                       when I did the ground up refirb on my MK2 in 2013 the OEM paint on the rack was badly chipped and water/road salt had got underneath causing it to flake and the ali fluff up = right mess !
So brought a can of Nitromores paint stripper, large dollop of elbo grease and Solvo Autosol and got to work.
This is the result  :good:
http://www.carpe-tdm..._299_281036.jpg
I just polish it up when it gets a bit dull, easy peesey job done.
Edited by Gdogg, 11 March 2019 - 06:14 pm.
#9 skedaddle
skedaddle
  • 52 posts
Posted 11 March 2019 - 06:45 pm
Hi Gdogg,
That came out really well.
Trouble is I don't have the standard rack. Bike came with a different grabrail, luggage rack and a givi plate.  And they all look fairly rough.  paint is flaking off and its rusted up.   I have the givi plate and the side racks off at the moment and want to put em back on but not in the state they're in. Think it will be paint stripper and elbow grease.
  • Attached File  1.jpg   252.09KB   1 downloads
  • Attached File  2.jpg   229.39KB   0 downloads
#10 dablik
  • 10,757 posts
Posted 11 March 2019 - 07:26 pm
If you have an angle grinder this will remove paint in minutes ready for a fresh coat, maybe just a rub over with 400 grit wet and dry after.
I paid less than that a while ago though, check ebay.
#11 PICARD
  • 1,744 posts
Posted 11 March 2019 - 07:32 pm
Plastikote (I think) does a good job. Looks a bit like powder coating. Get the satin finish iirc.
#12 divvxj
divvxj
  • 1,296 posts
Posted 11 March 2019 - 08:12 pm
Hi Gdogg,
I had the same side racks  as you , the sand blaster certainly helped but I used primer and then hammerite over the top ,but as you can see this is the best website for help as a few carpies have been through the same process , hope all goes well , and remember piccies before and after  :good:
#13 steve27bha
  • 784 posts
Posted 11 March 2019 - 08:14 pm
My sand-blaster used an etch primer on a frame he did for me, before I painted it with a rattle can filler-primer and topcoat.
However you only have a small area to coat and it is easily repaired so I'd go with Hammerite smooth black after a good rub down (missus). Take the bobbins, bungs and lock hasp off the rack to make the work easier.
#14 Matlock
Posted 12 March 2019 - 08:49 am
I've been fighting this battle for years with my Givi system on my 900 which I ride all year.
  • Powder Coating. Expensive and doesn't last in my experience. The coating lifted in the areas where the pannier mounts were bolted to the frame. There's a bit of compression and distortion of the mount here, which is the cause of the problem.
  • Cellulose paint. doesn't last again and takes a lot of prep.
  • Hammerite Smooth. This works, it must be flexible after it's dried, as the areas where the pannier mounts were bolted to the frame are still fine after two winters. Also preparation isn't vital, they claim you can spray directly onto rust. I actually used rust remover, then rubbed down and primed with a zinc primer. The end result is as good as powder coating visually and way better than Givi's original efforts.
#15 skedaddle
skedaddle
  • 52 posts
Posted 12 March 2019 - 11:55 am
Cheers Matlock, I'll give the hammerite a go so. I've used rust remover and hammerite on the subframe of a car before and that's held up well but wasn't sure about the finish. Thanks.
#16 Studley Ramrod
  • 19,214 posts
Posted 12 March 2019 - 02:35 pm
Do not google 'how to spray a rack' unless you have search restrictions in place beforehand. :huh:
I would prolly do similar to Matlock, remove and treat rust areas, key in old paint then use a galv coat for primer and finish with either hammerite smooth or similar rust preventative paint.
#17 madmopedracer
madmopedracer
  • 473 posts
Posted 12 March 2019 - 08:19 pm
I have used POR15 on a car Chassis it cures with damp and is tough as old boots
https://www.frost.co...lack-paint.html
not cheap but a little goes a long way
#18 skedaddle
skedaddle
  • 52 posts
Posted 20 March 2019 - 04:48 pm
Just an update on this. Got all the paint and rust off with a wire brush on a drill. Zinc primer and hammerite smooth, looks good so far. Will do one or two more coats. Cheers to all above for the pointers. Next job will be the radiator guard...
Edited by skedaddle, 26 March 2019 - 08:02 pm.
