Well, like a bad penny I'm back with another problem......
So, yesterday I ran the bike all morning with no issues then came to start her and no joy. Now, the battery's on its last legs an' I've had it on trickle charge every night for the last six months so after cranking it over for a minute or so it sounded goosed.
Luckily for me I'd stopped at the top of a big, steep hill so I jumped on thinking to myself "this should do the trick....I'll get her home, order a new battery and the job's a good 'un", and set off tryin' to bump her into life....
A mile later I'm at the bottom with the seat off checking the fuses in the hail, thunder an' lightening scratching my head.
Prior to this I'd just bin an' filled her up with Shell V Power (about 17 quids worth) an' a couple of other short journeys of about ten miles in total.
I got a lift home with her late on last night, put her on charge an' got up bright an' breezy this morning to make a start. She wouldn't go although the battery had taken a decent amount of charge. I noticed the yellow engine light started to flash while turning her over. There were no error codes showing so I decided to check through the diag codes.
When I got to the voltage check D09, I flicked the engine run switch an' got a reading of zero volts?, an' this is where I'm at now......question is have I made any school boy errors as far as checking the diag reading or anything else for that matter ?, an' if not has anyone got any suggestions as to what the problem might be before I start pulling her to pieces.....
P.S. sun's just come out here an' I'm getting desperate!
