Just seen this on the net,
Has anyone else seen it
http://s410372035.in.../yamaha-tdm900/
Edited by paddy900, 26 April 2013 - 09:14 pm.
Posted 26 April 2013 - 09:12 pm
Posted 26 April 2013 - 09:22 pm
Been posted up Paddy and i think Tam bought one..
Posted 26 April 2013 - 09:28 pm
Posted 26 April 2013 - 09:29 pm
You thinkin off getting one then Paddy !!
Posted 26 April 2013 - 09:35 pm
Oh I love the fame
Yes, that's my (now gone) TDM900 in the images
And the kit is a suberb bit of engineering
He who dies with the most toys wins
No more 2007 in white
In it's place is a big blue FJR1300
Touring Portugal? this is the perfect base
Posted 26 April 2013 - 09:40 pm
Looks interesting,
Undecided between it and a Vario touring screen
Posted 26 April 2013 - 10:27 pm
Posted 28 April 2013 - 12:50 pm
Hi folks. I bought one of these adapters direct from Palmer Products and took it on a test ride today so will give my views.
I had been using an MRA Vario screen for a while, and although it's a slight improvement it's not worth the money...in my opinion. The whole screen and front end design of the bike is bog. The screen angle is too shallow and it's set too far aft, so it's never going to work well, no matter how much higher the screen is.
I used the adapter with the standard screen and initially set it to a position one down from the most vertical and highest, shown here: (if this attachment works)
PICT0006.JPG 136.93KB 133 downloads
The most noticeable difference when I got to freeway speed was that I could hear the engine, and I've not heard it like that previously. The edge of the wind blast was hitting at the top of my visor, rather than in the middle of it, and that made a huge difference. It's the single biggest improvement in all the dicking around I've done with screens.
The adapter throws the screen some way off the original mounting points and there is a big gap, which helps it to work by letting air behind the screen. However I wanted to close that gap a little, mostly for when it's raining, so experimented some more. I fitted a cut-down section of an old screen at the bottom, extending some way behind. The top two mounting points on each side of the adapter screws got 3mm spacers behind to keep it all straight.
The additional screen section seemed to make things a little quieter again. It possibly helped by directing air flow up the rear of the raised screen.
The next photos show this lower screen section fitted and the adapter set to the highest and most vertical setting:
PICT0005.JPG 140.61KB 185 downloads
PICT0003.JPG 186.07KB 173 downloads
PICT0001.JPG 138.59KB 132 downloads
The highest setting was slightly quieter again, and the edge of the air blast was now just above my visor.
It's a bit weird-looking when fitted, but then so am I, so nothing lost there and I'm after functionality rather than looks. It throws the screen forward as well as higher and that does seem to be the secret to it.
More testing later, but it seems to be money well spent at this stage. It's expensive but a well-made product. Only change might be to paint the adapter black. ... g
Edited by gabby, 28 April 2013 - 01:00 pm.
Posted 28 April 2013 - 02:52 pm
Great write up.
You must have read my mind with the idea of adding a screen back on and cutting it to fit the bracket, though it looks like you have had to cut quite a bit of screen off.
Posted 28 April 2013 - 03:42 pm
Looks like KTM (Adventure), Aprilia (Caponord) and Kawasaki (Versys) have had the better idea all along, then, with their more upright screens?
Edited by Pict, 28 April 2013 - 03:50 pm.
Posted 28 April 2013 - 04:57 pm
I am sure that you can specify a black powder coat finish for the brackets
Posted 28 April 2013 - 08:37 pm
Great write up.
Thanks. I did cut a lot off but that was deliberate as there was no way to mount it securely at the top. The adapter hardware is in the way so you have to cut the original screen away in the vicinity of the top two mounting screws. There might be a way to leave more and mount it securely but I'm not sure how much it will improve it.
Posted 30 April 2013 - 06:14 pm
Gabby - how much flex do you get on the fairing now you have a greater screen area? I'm thinking of 50mph plus?
Ta.
Posted 01 May 2013 - 05:11 am
Ta.
I didn't notice any wild flexing at up to probably 70mph on those test runs. Having the air gap at the bottom is good for that reason too. I gave it a good pull test after fitting and I don't see it having a problem. But I would be careful adding a taller than standard screen
Posted 01 May 2013 - 12:36 pm
Posted 30 July 2013 - 08:36 pm
So with the MRA Vario screen , did you have the little one or the big one? I was thinking of buying the X-creen which is the bigger one , a decent screen is the only thing I miss on my last bike an XT1200,
Posted 30 July 2013 - 10:32 pm
Fwiw, the PP screen adaptor works better for me than the MRA Vario
Posted 31 July 2013 - 07:16 am
ive seen these on other bikes and they seem to work ok but i think it just dosent look right at all on the TDM with a huge gap between the screen & fairing ..
Posted 31 July 2013 - 06:22 pm
Thanks Pict , just looked at the PP website and I think this the way to go , I agree with doboy it is not a thing of beauty but looks like it will do the job , i'm not a scientist but apparently you need a gap at the bottom of the screen as well to balance the airflow or some such witchcraft . My previous 3 bike were an XT1200 an XT660 and a Buell Ulysses( worst bike I ever owned) but they all had these upright screens that split the air so well
Posted 31 July 2013 - 06:38 pm
I've been running it with a normal screen, but am curious to know what an MRA Vario would do. Looks don't matter much - the trike is a freak that invites modification anyway. Might even get enough lift like a triplane, and pop a few wheelies...
The only thing that in truth makes me nervous is the flex in the inner fairing over bumps or if the setting isn't right.
PS Never seen or tried an X-creen, but it does look interesting.
