Help Identifying Part
5 replies to this topic
#1 Quadsey
Quadsey
  • 52 posts
Posted 07 May 2019 - 01:12 pm
What is this part?
While changing the spark plugs yesterday i noticed this hose has completely sheered off at the base.
I suspect this happened a few months back as i noticed a change in sound of the bike but couldn't source why, thankfully I've had no performance issues to date.
I'm hopeful the part can be swapped out as it seems to be bolted on independently from the engine itself.
The photo i had of the parts separated seems to be corrupted so I've marked the photo where the split is, the hose can be fully removed away so the brake is right through.
"Touch not, less ye be touched" -Brodie 1995
#2 Studley Ramrod
  • 19,214 posts
Posted 07 May 2019 - 01:36 pm
Looks like the cover for the breather assembly.
Item no 21 here https://www.fowlersp...a/cylinder-head  listed as back order not in stock.
You could try searching ebay for the part number 5PS-14899-00
#3 Favs
  • 4,395 posts
Posted 07 May 2019 - 03:45 pm
Simply unbolt and take it to your local fab shop and ask them to weld it back together.  Distortion, if any, will be minimal and easy to flatten the mating surfaces with the old figure of 8 on a sheet of fine wet or dry paper stuck on a sheet of glass.
#4 Quadsey
Quadsey
  • 52 posts
Posted 08 May 2019 - 09:00 am
Thanks lads, I'll have a look now that i know what I'm looking for and see what my options are.
#5 MipeTDM
MipeTDM
  • 92 posts
Posted 11 May 2019 - 07:28 pm
New, also available for reasonable money, e.g.:
https://www.cmsnl.co...ase_5ps1489900/
#6 Quadsey
Quadsey
  • 52 posts
Posted 16 May 2019 - 06:45 am
Part is ordered, should be with me next week. I'll pop an update up once i get it swapped out. Provided the old part wants to come out!
