Error 19 On Dashboard When Starting (sometimes)
Posted 18 April 2012 - 02:47 pm
Sometimes when I try to start the bike (TDM 900 2002) this happens:
* the starter rotates for 3-4 seconds
* the bike does not start
* 19 is displayed on the dash
* the check engine light lights
* push the start button again, I can only hear the fuel pump, no starter
* turn key off/ back on - bike will start OK
Sometimes I need to turn the key on/off 3-4 times before the bike can start (and not display error 19).
I checked what is 19 and it says "open circuit to side stand switch". So I tried kicking around the side stand, it doesn't seem to make any difference. I also tried to switch into 1st gear, side stand on, try to start - only check engine light lights and the starter does not turn, also no error 19 is displayed.
I also did the following, traced the wires from the side stand switch and short circuited them with a U wire at the first connector so that it seems to the ECU that the side stand is always off. Now with this I can start the bike on 1st gear and side stand on while holding the clutch (so it works), but still from time to time I get the error 19, which doesn't make any sense.
What else should I look into?
Any suggestions appreciated.
Cheers,
Ivo
Posted 18 April 2012 - 02:58 pm
Fairly common, and various reasons.
This may help...
http://www.carpe-tdm...;hl=error code
Posted 18 April 2012 - 03:25 pm
This may help...
Posted 18 April 2012 - 04:22 pm
According to JBX's site, error 19 is a "side stand switch" fault.
Posted 18 April 2012 - 05:18 pm
Every time the bike is washed, they get doused in water and never really dried properly.
Posted 18 April 2012 - 09:17 pm
Had exactly the same myself.
Posted 18 April 2012 - 10:43 pm
Edited by celticbiker, 18 April 2012 - 10:44 pm.
Posted 19 April 2012 - 06:55 am
BTW I also got caught in a heavy rain last week and for 10 minutes or so the bike was like working on one cylinder under 3000rpm, above that it was all good, then when it dried out that disappeared, so I guess there is something going on with water/connectors/wiring.
Posted 19 April 2012 - 08:00 am
That one sounds like you need to read this thread:
http://www.carpe-tdm...showtopic=15971
Posted 19 April 2012 - 08:28 am
sorry just found it funny Adam linked ya again to another issue,,,,,, easy job and the bike will be sorted,,,good luck infestead...
Posted 19 April 2012 - 12:11 pm
Posted 20 April 2012 - 08:44 am
I cleaned all sockets around the air box, under the seat, near the ECU with contact cleaner and let them disconnected for 10+ minutes, then connected them again. Same story - error 19 here and there. I never got under the air box because I'm not sure how to disassemble there and I'm not too confident.
Another thing is that my spark plugs are ~29K miles old (iridium ngk), so I'm going to my mechanic to replace/check them this week and we also have a look at the connectors under the air box.
Posted 20 April 2012 - 09:27 am
Then just lift out the way - note that pipe are still connected, but give you enough space to work.
Posted 03 May 2012 - 07:28 pm
I finally managed to clean those connectors:
http://i.imgur.com/WuJIg.jpg
Contact cleaner on all, left disconnected for 15 minutes then connected them back, I couldn't spot moisture or corrosion anywhere, just on one the male plugs were a bit "greenish" but only a bit. Now I get 19 error less often but still. When it starts it starts immediately, but when it doesn't it sounds a bit different and rotates kind of faster. I don't get the 19 error immediately - only after trying to start for 5 straight seconds or so, key off/on and it starts.
Do you think I should change my spark plugs as well - 29K miles on them? I haven't adjusted the spacing ever or anything.
Edited by infestdead, 03 May 2012 - 07:30 pm.
#16
Posted 08 May 2012 - 06:30 am
#17
Posted 08 May 2012 - 07:27 am
Yes.
Posted 08 May 2012 - 08:01 pm
Kin ell CB. Got your moneys worth out of them.
