Original on left, new on right of picture
Posted 13 January 2019 - 02:23 pm
Posted 13 January 2019 - 08:48 pm
From memory (er umm), of my 4tx, it is correct. I think L n R are different bowls
Posted 13 January 2019 - 10:13 pm
Don't think so - does the spigot not lead to a drain screw?
They are a pain cos they made the bowl fiddly to refit
Edited by dandywarhol, 13 January 2019 - 10:14 pm.
Posted 14 January 2019 - 10:09 am
It's an overflow pipe.
Posted 14 January 2019 - 12:21 pm
interestiong that ‘collective wisdom’ might eventually identify the function of the extra bit,
but.......
.......it seems that what’s then relevant is that the replacement part contains a ‘something’
that the original didn’t.......is the lack of that ‘something’ on the original an explanation for
some malfunction?......or if not, should that bit be removed (if poss.) before installation,
or was that something mislaid during dismantlement
......and so on
Jiff
Posted 14 January 2019 - 06:58 pm
As Studders said Its an overflow from the carb ---When fuel gets above it (carb flooding) It overflows through it and down the overflow tube--Which means the one without will always overflow and the carb wont fill up or someones blocked it off so all overflow will drop onto your engine and go pop when it all ignites.
Posted 15 January 2019 - 06:50 pm
Interesting, memory coming back now - My original 850 (bought new, 1996 mode) didn't have the overflow tube and would frequently fill the exhaust when standing for a few weeks. The first time I started the engine and the resultant explosion near blew the bloody doors off and caused my sphincter muscle to relax. A later model of carbs I stripped had the brass tube!
Posted 15 January 2019 - 10:28 pm
.....so presumably, fitting the replacement part, complete with brass tube, might, on its own, work fine with the additional benefit
of making overflow problems less likely ?
.....or would other mods be required, makiing fitting of the replacement part inappropriate ?
Jiff.
Posted 16 January 2019 - 09:50 am
I've come across carbs that have a spigot in each bowl and others where there is only one spigot. No idea why though.
Posted 16 January 2019 - 04:39 pm
Yep, my '99 build 4tx had brass in one and blank in t'other IIRC & I think only 3 screws holding the bowl on. Mine was an unrecorded cat C, so maybe not std.
