Oil Pressure Gauge For Tdm 850
10 replies to this topic
#1 toddyboy
toddyboy
  • 121 posts
Posted 20 March 2018 - 01:34 pm
I have a 1997 very low mileage TDM 850 4TX2
I need to change the oil and filter shortly and also want to somehow install an oil pressure switch and gauge to it
Has anyone done this previously and if so could you give me a few pointers please?
#2 Studley Ramrod
  • 19,214 posts
Posted 20 March 2018 - 02:25 pm
Pointy pointy http://www.carpe-tdm...showtopic=17013  :)
#3 tdmpaul
tdmpaul
  • 201 posts
Posted 20 March 2018 - 09:07 pm
i fitted one of lee henty’s kits to mine, works great, no hardship to fit.
#4 drewpy
  • 1,758 posts
Posted 21 March 2018 - 11:25 am
the hardest part is fitting the oil light in the cluster and making it look oem.
#5 Pjkr44
Pjkr44
  • 91 posts
Posted 21 March 2018 - 12:18 pm
Sorry to be dim, but what's the purpose of monitoring the oil pressure?
I know little about mechanical side of bikes, want to know. Thanks
#6 dapleb
  • 18,117 posts
Posted 21 March 2018 - 12:39 pm
It gives you a clue if you is about to run out of oil if ya can't read a dipstick/sight glass
#7 Pjkr44
Pjkr44
  • 91 posts
Posted 21 March 2018 - 01:09 pm
That's convenient with oil-thirsty tdm :) thanks! And what the switch do? Turns the gauge on/off?
#8 jiff
jiff
  • 688 posts
Posted 21 March 2018 - 06:05 pm
a.f.a.I.k ‘switch’ is what takes the reading (measures the oil pressure in the engine)..... and communicates a value ( lbs. of pressure )
which shows on the gauge .......
or
(as in the splendid ‘Henty Kit’) lights up a red indicator light when the ignition is switched on and oil pressure is low - which should go off once the engine is turning over at speeds above tickover......if it doesn’t go off.......you have low oil level / a problem
jiff.
#9 jiff
jiff
  • 688 posts
Posted 22 March 2018 - 09:32 am
.......Oh! , and with all those rotating / reciprocating parts moving / bashing against each other inside the engine, lubricating the surfaces ‘smoothes the path and the interface’ and minimises wear and tear.....and damage
low pressure = insufficient lubrication
jiff ( he of minimal understanding, struggling to join up words)
#10 Pjkr44
Pjkr44
  • 91 posts
Posted 22 March 2018 - 09:36 am
How great is to learn things. Thanks for explanations.
#11 Bjørge
  • 1,792 posts
Posted 22 March 2018 - 01:07 pm
This could work, right ?
https://www.motorspe...ryter-skruetype
