I want to fit a buzzer. Can I connect to the two terminals inside one front indicator (one is coloured, one black) and safely assume that the black is the earth? The unit's other red wire I would take to the other front indicator (for my MT-03). Seems logical but is it right? (I cannot source a wiring diagram at mo.)
Robo
Indicator Buzzer
Started by
Robodene
, Sep 15 2012 01:49 pm
4 replies to this topic
Posted 15 September 2012 - 01:49 pm
Posted 15 September 2012 - 02:23 pm
.........assuming your not concocting a 'bitsa', then, if it's like mine, it'll come, off the shelf, with a wiring diagram which will inform...
assuming no-one with ACTUAL KNOWLEDGE comes along, I'll try to dig out the diagram in question, & flag it up
.......Jiff
Posted 15 September 2012 - 03:13 pm
QUOTE(jiff @ Sat 15th Sep 2012, 15:23 PM) <{POST_SNAPBACK}>
.......Jiff
.......Jiff
Thanks, jiff. It's an online off the shelf type. I suppose my main worries are about connecting at the indicator, and is the black wire the earth or not.
Robo
Posted 15 September 2012 - 06:28 pm
..........found the original diagram as supplied (indicator-buzzers.com) which shows two red wires from the buzzer, one going to the live side of the left and the right indicator respectively.
The black wire goes to any earth.....
Hope this helps......Jiff
Posted 15 September 2012 - 10:36 pm
QUOTE(jiff @ Sat 15th Sep 2012, 19:28 PM) <{POST_SNAPBACK}>
It does, thank you. Now, I will order one.
Robo
