So there I was, engine back together, new plugs, oil and coolant in, exhasust back on in anticipation of the roar. The roar was more like a 60-a-day's bad cough. After the bike kicked in it wouldn't idle, didn't like the choke and could only start it with a little throttle. Turned the idle cable up a bit and she would tick over, but not like she used to, so out came the coolant, off comes the rads and the cam cover again. As far as I was aware, it did everything the Haynes and service manual told me. Both dotd on the came were pointing up,
But the bike was firing wrong like this. When the bike is set at TDC inlet on cylinder one is almost at full stroke and C2 exhaust is the next to follow,
Now this is where it goes wrong (I think). the inlet on C2 and exhaust on C1 are firing at the same time,
The timing marks on the end of the cams are correct too,
Can anyone point out to me where I've gone wrong? I'm glad I've done this now as Id be in a right pickle if my trip to Spain was a lot closer. I want to take the TDM but if all ales fails, I'll take a VFR. Thanks folks.
