Piston Skirt Coating And Down Pipes Kerachrome
30 replies to this topic
#1 drewpy
  • 1,758 posts
Posted 05 June 2020 - 12:13 pm
Hi Folks,
Just picked up my pistons and downpipes from Camcoat in Warrington.
I must say they have done a cracking job on them and the piston skirts just need a little bit of buffing with a 3m pad to get the proper clearance.
The reason I went for the downpipes Kerachromed is the fact that the coating doesn't spoil over time and stays that way (we'll see) this wasn't cheap though as for a few £'s more I could have bought new ones.
I would def recommend the pistons if they are slightly over the wear limit as this take-up the wear.
Attached File  IMG_0868.JPG   90.95KB   0 downloads
Attached File  IMG_0867.JPG   178.89KB   0 downloads
#2 Bjørge
  • 1,792 posts
Posted 05 June 2020 - 12:44 pm
Wow !  :badgerrock: Beautiful !
#3 leehenty
  • 5,090 posts
Posted 05 June 2020 - 12:52 pm
Nice
#4 TKH
Posted 05 June 2020 - 01:23 pm
Hope the pipes stay clean. :badgerrock:
#5 drewpy
  • 1,758 posts
Posted 05 June 2020 - 01:34 pm
should be easier to wash.
just need to take any finger prints off before firing up as they can burn in due to the coating still hardening
#6 Studley Ramrod
  • 19,214 posts
Posted 05 June 2020 - 02:56 pm
Cool. :cool:
#7 dablik
  • 10,757 posts
Posted 05 June 2020 - 03:38 pm
I like :good:
Drew do you know which downpipes they are, they look identical to mine and i have'nt a clue, possibly Black Widow !
#8 leehenty
  • 5,090 posts
Posted 05 June 2020 - 05:32 pm
Next question is how spendy is it?
#9 drewpy
  • 1,758 posts
Posted 06 June 2020 - 08:54 am
I like :good:
i had a gps can which I've replaced with another GPS
pistons £49 downpipes £90 all plus vat and delivery, although I live 1/2 hour away so picked them up.
Cost 168 inc vat
#10 drewpy
  • 1,758 posts
Posted 09 June 2020 - 04:22 pm
engine is now more or less built.
I've ordered some thread lock for the cam bolts that hold the cam wheel to the shaft after the near miss of one hanging off.
one more thing. I have a small wire bracket that was sent with the cylinder head and the fiches don't show it, only on tenere.
What does is protect and where do you think it will go on the intake manifold?
I guessed this one but happy to change it whilst engine is on the bench
#11 Studley Ramrod
  • 19,214 posts
Posted 09 June 2020 - 06:02 pm
Here's where the bracket was on my mk2a, you can just see it on the right of the right inlet.  It was used to guide the vac pipe down the right side of the engine.
Attached File  mk2aoil tankoff2.jpg   103.38KB   0 downloads
Item No.9
#12 drewpy
  • 1,758 posts
Posted 09 June 2020 - 06:44 pm
brilliant, thanks :good:
#13 drewpy
  • 1,758 posts
Posted 16 June 2020 - 12:15 pm
Attached File  IMG_0977.JPG   156.9KB   0 downloadsAttached File  IMG_0978.JPG   182.2KB   0 downloadsAttached File  IMG_0982.JPG   138.2KB   0 downloadsEngine finished now, just waiting for a break in the downpours to fit it to the frame.
#14 Snowbird
  • 1,359 posts
Posted 16 June 2020 - 12:24 pm
While that oil tank is nicely exposed has anyone considered fitting a level sensor?
#15 Bjørge
  • 1,792 posts
Posted 16 June 2020 - 01:38 pm
I have  :)
Thought about buying one for the 9er and try squishing it into my oil tank. Then I got to think of the lack of oil consumption.....and skipped the idea  :rolleyes:
#16 dapleb
  • 18,118 posts
Posted 16 June 2020 - 02:26 pm
Lick lick
#17 Rallyist
  • 3,253 posts
Posted 16 June 2020 - 02:32 pm
I have  :)
The 900 already comes with an oil level sensor  inside the oil tank
#18 dablik
  • 10,757 posts
Posted 16 June 2020 - 03:43 pm
Nice job drew, i found it really quite easy to mount  the rear upper bolt and i could pivot the engine to line up other mounts.
#19 drewpy
  • 1,758 posts
Posted 16 June 2020 - 04:05 pm
good idea, was going to do the rear lower first and push up, but I'll let gravity help me
#20 Studley Ramrod
  • 19,214 posts
Posted 16 June 2020 - 04:57 pm
Sminky. :)  Great job Drew. :good:
