Off-Centre Front Wheel, Forks "too Wide"
Front wheel Front brakes
7 replies to this topic
#1 Richardhuddleston
Richardhuddleston
  • 11 posts
Posted 30 January 2019 - 04:26 pm
Changed fork oil (sludge) on 2004 TDM900.  Refitted all.  Come to tighten wheel spindle up and this -  3mm gap between spacer and fork:
IMAGE 11Attached File  IMG_0011.JPG   115.32KB   0 downloads
When it should look more like like this - spacer flush to fork (bearing seals removed deliberately):
Attached File  IMG_0010.JPG   135.4KB   0 downloads
(I'm sure this gap wasn't there before I had forks off).  So disk rubs on inside of brake calliper.  Other side's ok because spindle's threaded and nips spacer up to fork. There's nothing to stop this side of the spindle going all the way through the fork, so it doesn't nip up.
I've slackened and rotated both forks through 90deg / 180deg / 270deg and checked gap; stays same so forks aren't bent.
Wheel bearings are ok.
A work-around is to torque the wheel spindle up, nip forks together with a g-clamp, THEN nip the spindle clamp screw up to hold it all in place.  But it seems like an unsafe bodge.
Any ideas folks?
UPDATE:
I slackened everything off and removed mudguard, squeezed forks together with a G clamp and nipped spindle clamp up then tightened everything from bottom up, mudguard on last.  Took it for a spiin then slackened spindle and clamp to see what was what.  The gap was still there but not as big.  So I did the G-clamp thing again.
Seems to handle fine (better with new fork oil actually) so I guess that's not an issue.  Something to just be aware of I suppose.  Maybe the bushes had just worn into one place and got disturbed when I stripped the forks and they'll settle back in with time.
Thaks for all the suggestions guys.
Edited by Richardhuddleston, 19 March 2019 - 10:23 am.
#2 Favs
  • 4,395 posts
Posted 30 January 2019 - 07:19 pm
Attached File  2004 front wheel.jpg   54.93KB   0 downloads
Check parts present.
#3 dablik
  • 10,747 posts
Posted 30 January 2019 - 08:00 pm
Here you go have a read, scroll down to post 53, mine was'nt so out of alignement as yours but the fix is posted further down, just a matter of undoing and doing up the hardware again..
Edited by dablik, 30 January 2019 - 08:06 pm.
#4 wicklamulla
Posted 30 January 2019 - 09:39 pm
so i read that from post 53 onwards,  did you get that spacer / fork gap down to zero  then?
#5 JBX
Posted 30 January 2019 - 11:43 pm
1 - Did you not forget to put the collars on both sides ?
2 - Before tightening the wheel axle nut, push down hard on the handlebar several times and check if the front fork rebounds smoothly. This may help all parts to get into the right position.
In case there is still a small gap, clear it by pushing the rhs fork leg inward, then tighten the wheel axle pinch bolt and finally check the front fork rebounds smoothly.
Edited by JBX, 30 January 2019 - 11:45 pm.
#6 dablik
  • 10,747 posts
Posted 31 January 2019 - 10:42 am
Sure did matey, loosened it all off a 2nd time after a little run out, i had serviced forks, off and back on a multitude of times before that event, the only difference being that i had put a new lower yoke on the bike, in the end the forks just needed loosening up and tweaking to fit properley, must of got them skew wiff at some point.
Edited by dablik, 31 January 2019 - 10:49 am.
#7 dandywarhol
Posted 31 January 2019 - 02:24 pm
Also tighten the mudguard bolts last
#8 JBX
Posted 31 January 2019 - 07:01 pm
Dandy is right and I forgot to write that both callipers should be fitted/tightened after the front wheel is in place.
Also tagged with one or more of these keywords: Front wheel, Front brakes
