Tdm 900 03 Non Starter
15 replies to this topic
#1 Johnotdm900
Johnotdm900
  • 25 posts
Posted 04 February 2019 - 09:34 pm
Hi all.. my 03 tdm 900 wont start.. it turns over but doesnt fire.. the spark plugs have little spark so im replacing them tomorrow.. does anyone have any similar problems and remedies? Thanks
#2 wicklamulla
Posted 04 February 2019 - 11:48 pm
battery good and fully charged,  fresh fuel, side stand is in the up position, have you looked at the error codes? HT leads arcing out to the frame?
#3 JBX
Posted 04 February 2019 - 11:53 pm
Very few chances it's caused by the plugs but who knows ?
Clean and check plugs gap beforehand, plugs on an injected engine last longer than on a carbed engine.
Tell more about your bike and its maintenance history.
I had a similar issue, it was an injection failure due to bad fuel which clogged the injectors.
Side-stand down gives the same result as the engine kill switch off.
Weak HT leads ?
#4 wicklamulla
Posted 04 February 2019 - 11:55 pm
Weak HT leads ?
yes quite likely they are  weak and leaking.
#5 dandywarhol
Posted 05 February 2019 - 12:35 am
I know how that feels.................................................................................  :pimp:
#6 Johnotdm900
Johnotdm900
  • 25 posts
Posted 05 February 2019 - 07:39 am
Thanks for the replies.. its a TDM 900 5ps which has had the basic maint done every year however i have never changed the plugs in 3 years.. i sit on the motorway in all wheather for about 140 mile per week.. i hope its the plugs as this is a relativley easy fix.. other than that i have no clue..
#7 fixitsan
  • 4,676 posts
Posted 05 February 2019 - 08:03 am
Can you hear the fuel pump whirr when you turn the ignition on ?
#8 CrashTestDuffy
CrashTestDuffy
  • 124 posts
Posted 05 February 2019 - 10:23 am
Mine was in with the same issue last month, the connections under the tank had corroded from exposure (not totally protected from elements and road crap under there) so it was turning over but never priming.
#9 Favs
  • 4,395 posts
Posted 05 February 2019 - 10:48 am
Lol
#10 Johnotdm900
Johnotdm900
  • 25 posts
Posted 05 February 2019 - 11:02 am
What connections
#11 CrashTestDuffy
CrashTestDuffy
  • 124 posts
Posted 05 February 2019 - 11:16 am
Iirc there's a male-female connector block under the tank on the left (clutch) side. Could not tell you specifically what it connects, just that the mechanic had to clean the spades in it and change a couple outright to get it going again.
#12 fixitsan
  • 4,676 posts
Posted 05 February 2019 - 12:03 pm
Connector maintenance is worth doing, annually. Just open and close all connectors and you make a good difference,. Apply a contact lube with corrosion inhibitors and you'll have very few electrical problems. The connectors under the tank are all worth splitting open, and all relay plugs too.
Edited by fixitsan, 05 February 2019 - 12:07 pm.
#13 Johnotdm900
Johnotdm900
  • 25 posts
Posted 05 February 2019 - 03:26 pm
Cheers.. its defo worth a shot before i put the side pannels and radiator back together..
#14 divvxj
divvxj
  • 1,296 posts
Posted 05 February 2019 - 05:10 pm
wire corroded on the fuel pump , took the mechanic ages to figure it out
#15 JBX
Posted 07 February 2019 - 09:56 pm
Yes, check for wires & connectors corrosion !
I always forget to mention that problem but it's very common in countries with a damp weather.
#16 TKH
Posted 07 February 2019 - 10:21 pm
Don't rub it in! :P
