Looking For Some 6-40 Unf X 3/4" Set Screws With Hex Heads
19 replies to this topic
#1 dapleb
  • 18,114 posts
Posted 24 September 2018 - 06:06 pm
Mr Wharton can get me a box of 200 for £30+but oi only need 2.
Anyone know of any? Have tried a load of places on lion without any luck.
They are close to M3.5 X 20 which may work but I can't really find them either.
#2 Studley Ramrod
  • 19,213 posts
Posted 24 September 2018 - 07:12 pm
I can ask my local supplier tomato, see if they've got 'em. :)
#3 dapleb
  • 18,114 posts
Posted 24 September 2018 - 07:14 pm
Ta SR. Yes peas.
#4 Studley Ramrod
  • 19,213 posts
Posted 24 September 2018 - 07:29 pm
Found a socket head bolt - pack of 10 fer £2.85.  Any robin hood ?
https://www.westfiel...ine_0.1380.html
Will still ask my supplier tomato.
#5 dapleb
  • 18,114 posts
Posted 24 September 2018 - 07:57 pm
Ahh a hex would be ideal but that's better than I managed ta.
#6 TKH
Posted 25 September 2018 - 02:39 am
Have you tried ebay?
#7 dapleb
  • 18,114 posts
Posted 25 September 2018 - 05:38 am
Yes TKH. Though it just gives me ERR TOO MANY REDIRECTS message these days, I had a look on Tishabelles phone.
#8 Studley Ramrod
  • 19,213 posts
Posted 25 September 2018 - 09:28 am
I googled american nuts and bolts. :)
No joy with my local supplier unfortunately, they do stock UNF but nothing as small as you're wanting.  No M3.5 either.
#9 dapleb
  • 18,114 posts
Posted 25 September 2018 - 11:04 am
Thanks fir chicken SR. The Allen key ones are a great find, just that bolts are awkward to get to when on car and are holding an electric gizmo that fails for fun... Normally requiring roadside removal of component....I might have one of them Allen sockets somewhere as otherwise would lose the Allen bit when trying to remove.
#10 Studley Ramrod
  • 19,213 posts
Posted 25 September 2018 - 03:10 pm
Could you possibly tap out the holes to M4 then use standard bolts ?  Or you wanting to keep it original ?
#11 dapleb
  • 18,114 posts
Posted 25 September 2018 - 04:12 pm
That might be possible. The bolts go through the electrical dokickey in a metal sleeve as they also earth the component. Might be enough meat on the metal bushes to tap... Good stinkin.
#12 drewpy
  • 1,758 posts
Posted 25 September 2018 - 07:35 pm
no idea what 6-40 means but I use these guys for my fixings
http://www.a2a4.com/..._STAINLESS.html
#13 Favs
  • 4,394 posts
Posted 26 September 2018 - 10:39 am
6 is the screw size (from #1 -#12 diameters bigger begin at 1/4" after #12) and 40 is the number of TP.I
UNC UNF & UNEF use the same system. of diameter and TPI number combination
#14 drewpy
  • 1,758 posts
Posted 26 September 2018 - 09:31 pm
thanks, prob I'd knew that once but using metric for so long its become 2nd nature for me now.
#15 Studley Ramrod
  • 19,213 posts
Posted 27 September 2018 - 09:06 am
There's also whitworth, or as I like to call it WTF ! :P
#16 dapleb
  • 18,114 posts
Posted 27 September 2018 - 09:54 am
: lolzio:
#17 Favs
  • 4,394 posts
Posted 28 September 2018 - 11:10 am
Is this a cycle thread?
#18 dapleb
  • 18,114 posts
Posted 28 September 2018 - 02:46 pm
My use is for a Brum brum not Treader. As it turns out.... The new dist base had a different thread in it anyways GRRRRR. I have just fitted phirrips head till I can sort out what the new size is but it snot 6-40 as old bolts don't fit!!!
#19 Favs
  • 4,394 posts
Posted 01 October 2018 - 08:04 am
If not metric or UN could be British Association  - a 4 or 5BA is about the same diameter - especially if your running an older Brit motor.
It was the first thread I ever cut on a lathe, right after making the tool to cut it -1975 it were.
Handy Thread Link;
https://britishfasteners.com/threads/
HTH
#20 dapleb
  • 18,114 posts
Posted 01 October 2018 - 09:39 am
Ta favs. I suspect the new thread of metric, prolly M3.5 or 4.
