Confession!.... Followed By Advice Seeking
25 replies to this topic
#21 TKH
Posted 24 May 2020 - 03:24 pm
Getting  quick shifter is around £250 - £300. Think I'll stick with my dirt bike thingy for now.
#22 dandywarhol
Posted 24 May 2020 - 06:30 pm
A cheaper trick would be to use the headlight flash switch to break the ignition circuit for a few milliseconds. Switch it as you press the gearlever and it acts as a mechanical quickshift.
I used it when racing proddy bikes - I used the horn button - until the scrutineers insisted the horn worked AFTER the race!  :pimp:
#23 Kelpie
Kelpie
  • 944 posts
Posted 24 May 2020 - 07:38 pm
I think we all ache a bit when riding out after being grounded on lockdown. Youll probably find youre ok once youre riding fit. Me and BSM have been out for a couple of 90 mile spins in the past week and we were both a bit stiff and knackered afterwards. Itll come back though. Same after any significant break. But agree you shouldnt be covering your clutch.
I dont believe clutchless gear changes do any harm if you get it right. Some may remember me busting my left hand badly after crashing the R1 on the track some 10 years. I had to perfect clutchless changes, both up and down and still do it as a matter of course when the notion takes my fancy. Shifting down takes a bit of practice but it can be achieved very smoothly once you get the knack.
#24 Snowbird
  • 1,358 posts
Posted 28 May 2020 - 08:14 pm
Well my master cylinder and slave for clutch turned up today and it seems the bores are a mismatch for the job, very short/heavy lever pull and the slave seems to return very slowly to the point it's likely to make the clutch slip like mad, it's either try and sleeve the master down and make smaller piston and drill fluid return hole bigger or give up.
May give it a go, spent the money now so nowt to lose really.
#25 Hombre
Hombre
  • 448 posts
Posted 04 November 2020 - 05:28 pm
I have the Rox bar risers.  Up is ok but up and back is restricted by the length of cables, clutch primarily but throttle also.  Further back would be better so only partly successful.  I see Banggood have copies.
The stunt clutch could help with clutch cable length but then I'd be up against the throttle cable length. :(
Edited by Hombre, 04 November 2020 - 05:33 pm.
#26 MipeTDM
MipeTDM
  • 92 posts
Posted 05 November 2020 - 11:36 am
Also the swept back angle on the original bars (at least on the 850s) are sub-optimal on our wrists. I read than many of us substiture those with other bares e.g the "Renthal" brand, with a different angle. I also find this but haven't tackled this bars issue yet myself.
