Third Gear Whine
4 replies to this topic
#1 frogturn
frogturn
  • 15 posts
Posted 25 May 2020 - 09:43 am
Hi Folks,not been on the forum since I sold my 900.ive now bought a 99 850 in good shape.
Except a noisy third gear.it rides well.
A brief look on the interweb suggests this is a comonish problem.
Bearing,chipped teeth or case hardening fail.
I dont mind stripping to solve as its a goodun.
So the questions are.
Is there a known fix?
Can I strip the motor by leaving the barrels and top end in situ,and separating the cases to get at the gearbox internals?
Many thanks,Paul.
#2 dapleb
  • 18,114 posts
Posted 25 May 2020 - 10:02 am
Known fix err a few threads but most MK1. Will depend somewhat on what you find worn.
You can't leave top end and barrels in situ, no.
Heard of some MK2 with whine but not normally the bigger problem of boike jumping out of turd.
There is considerable gasket expense in rebuilding Juan of these so I'd investigate all possible easy solutions first afore deciding on rebuild.
..and welcome back.
#3 drewpy
  • 1,758 posts
Posted 25 May 2020 - 12:27 pm
If its just whine, that's normal so your fine.
Depends on how loud it is. my 96 has been whining since I bought it
#4 Studley Ramrod
  • 19,213 posts
Posted 25 May 2020 - 05:17 pm
:wifgeni:
Replacing the gear/gearbox is pretty expensive, even more so if you need to refurb the top end as well.  I found disturbing then refitting original piston rings just gave me mahoosive oil consumption after I'd replaced the gearbox.  I ended up doing a top end refurb.
#5 MickC
MickC
  • 408 posts
Posted 25 May 2020 - 07:17 pm
Like Drewpy I have a 96 and it has a bit of a whine,gearbox works fine how long are you in 3rd for leave it as it is if the gears  go in and stays in gear leave it.
