Mk1 Drivechain Stretch Limit
10 replies to this topic
#1 Studley Ramrod
  • 19,213 posts
Posted 06 June 2020 - 06:21 pm
Just checked my drivechain 10 link length using the excellent tool from Celticbiker  :good:  and it looks like I'm bang on the limit of 150mm.  I suspected as much as the chain is making weird noises when man hoovering the bike foreward and backwards.
Anyhoos, when I checked in with the Haynes book of wonderment I noticed that, despite the mk1 and mk2 having the same identical chain, the mk1 10 link stretch limit is 150mm but the mk2 limit is 159mm. :huh:  Anyone care to explain why this might be other than a typo ?
I'm gonna check in on the front sprocket to see if it's still loctite secured before biting the bullet on a new C&S kit.
#2 dapleb
  • 18,114 posts
Posted 06 June 2020 - 06:49 pm
Haa hoo humm.
Can check in yam book when I'm next there, see what that says. Quite a diff that.
#3 Studley Ramrod
  • 19,213 posts
Posted 06 June 2020 - 07:41 pm
Cheers Daps, be good to know. :good:  The 9'er has a limit of 150.1mm.
#4 dablik
  • 10,747 posts
Posted 07 June 2020 - 07:53 am
Well i was gonna say would the longer swing arm account furrit but then i saw the 9r referance, ya think a Haynes typo !
#5 dapleb
  • 18,114 posts
Posted 07 June 2020 - 02:31 pm
So I had a mission for 2 items....
Dyson DC04 drive belt... 30mins LOCATED
YAM BOOK ...45mins ... GAVE UP
Got home, peered in loft and it was there!!!!
10 link length limit = 150.0mm
This happens to be 5.91".....which could be misinterpreted as 159mm if ewe have discaclulia and mix-a-ma-units .... Trying to be kind to Heinz.
#6 Studley Ramrod
  • 19,213 posts
Posted 07 June 2020 - 03:30 pm
:lol: That would make sense actually. I scanned the mk2 service manuel and there's no reference to chain stretch limit, a bit odd when the mk1 and 9'er manuels both have it.
Thanks for digging out the info, muchly appreciated. :good: Now go get that hoovering finished.  :P
#7 leehenty
  • 5,085 posts
Posted 07 June 2020 - 07:03 pm
DC04 ? That's practically a museum exhibit.
#8 dapleb
  • 18,114 posts
Posted 07 June 2020 - 08:11 pm
My nephew has been a vacuum enthusiast since the age of 3!!!! Very knowledgeable and able to service all. Don't mention museum piece or the little bugger will have it in his collection.
Has a collection of 40+ of various makes & models.
Now aged 8 he don't seem likely to give up the vacuums but have at least got him in to land rovers too. :0)
#9 Studley Ramrod
  • 19,213 posts
Posted 07 June 2020 - 09:33 pm
Do you offer to let him try them out at your house ? :D
Older wans have more suck. :oldgit:
#10 Rallyist
  • 3,251 posts
Posted 08 June 2020 - 07:46 am
That's modern I am still using a DC01  :good:  :)
#11 wicklamulla
Posted 09 June 2020 - 11:00 am
One cud say he's a sucker ferret.
[quote name="Studley Ramrod" post="380092" timestamp="1591565585"]Do you offer to let him try them out at your house ? :D
Older wans have more suck. :oldgit:[/quot
Good swipe at 900 riders there lad.
