What the heck is it and why must I endure it?!
Edited by SeizedBalt, 11 July 2021 - 11:38 am.
Posted 11 July 2021 - 11:37 am
Posted 11 July 2021 - 12:24 pm
A switch to full synthetic oil oil didn't stop it, but did reduce it..
Neither did a clutch strip.
Neither did new heavy springs.
Nor did Gecko clutch plates n springs.
It no longer annoys me as much as screamer pipes on dreary cars......
Posted 11 July 2021 - 04:30 pm
Cos it wants to be a Guzzi.
Posted 11 July 2021 - 07:59 pm
Guzzi clutches don’t squeal like a niner, but they do rattle like f*@#k when you pull the clutch lever in. Probably as bad as a Ducati.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy, Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators Currently not fitted - PC3, Remus Revolutions.
Posted 11 July 2021 - 08:10 pm
Posted 11 July 2021 - 08:14 pm
Posted 11 July 2021 - 09:15 pm
Was that the one where the guy shimmed the clutch boss springs ? Had to grind off the rivets or summat like that.
Posted 11 July 2021 - 09:45 pm
Just to add…I’ve always found fresh oil helps (I use Motul 5100), but even then, it still does it when cold.
Posted 12 July 2021 - 12:35 am
A change of oil will help but you will need to experiment to find the right one. I use an Australian full synthetic oil Nulon 10w-40 and it has completely removed the squeal. I had the bike serviced at a local shop a few years back and they used Motul. The squeal returned on the ride home, I changed the oil that afternoon, problem solved.
Posted 12 July 2021 - 07:48 am
yes dare was but i cannot remember who twas?
Posted 12 July 2021 - 07:55 am
