When Your Tinkering Day Goes To Another Level
49 replies to this topic
#1 catsbum
Posted 06 July 2020 - 04:58 pm
So ChrisR and myself took a ride up to see Mr Henty. I had some bits for him and in return he did some bits for us!
What a great day out. I was fascinated and memorised the whole day. "Think we will need a new bolt for there. I'll go make one" ......I just stared as he fired up the Lathe!
A true Engineer in every respect. About 213 miles in the day, Sunburnt and the wind nearly took us out several times but home with a smile on my face.
A big thank you Mr H.
Cats
Before and after to follow:
Edited by catsbum, 06 July 2020 - 05:00 pm.
#2 dapleb
  • 18,117 posts
Posted 06 July 2020 - 05:12 pm
Lubbly.
#3 leehenty
  • 5,088 posts
Posted 06 July 2020 - 05:20 pm
That photo of the lathe is parting off from the 25mm bar of 316 stainless, with a Swiss made 2mm carbide parting tool.(One of my favourite lathe tools)
The tips cost £5 a throw so I look after mine with plenty of coolant.
I tried to get you both on the lathe,
there isn't much to it.
I had to do something, I just couldn't put that corroded bolt back.
Edited by leehenty, 06 July 2020 - 05:27 pm.
#4 dablik
  • 10,754 posts
Posted 06 July 2020 - 05:27 pm
Good job Lee :good:
#5 leehenty
  • 5,088 posts
Posted 06 July 2020 - 05:31 pm
That fancy phone he has, must be good in the camera dept, it captured the steam from the coolant.
#6 ramo
ramo
  • 1,179 posts
Posted 06 July 2020 - 06:59 pm
You should have made him a chain Lee
or told him how to clean one, tut tut, you must try harder catsbum  :rotflmmfao:
#7 Studley Ramrod
  • 19,214 posts
Posted 06 July 2020 - 07:05 pm
Nice. :cool:  Good stuff Lee.  Thanks for sharing Cats. :good:
#8 Pedro
Pedro
  • 266 posts
Posted 06 July 2020 - 08:12 pm
How those blingy things come out of a spinning piece of metal I'll never know. That's some special talent alongside harnessing nuclear power.
Edited by Pedro, 06 July 2020 - 08:13 pm.
#9 leehenty
  • 5,088 posts
Posted 06 July 2020 - 09:07 pm
There isn't much to it really. Digital readouts do much of the calculation and provide a repeatable zero. Then it's just feed speeds and compound angles. Modern carbide indexed inserts tooling helps a lot. Very little grinding tools now.
Edited by leehenty, 06 July 2020 - 09:07 pm.
#10 AliG
  • 1,446 posts
Posted 06 July 2020 - 09:52 pm
He lost me at digital readouts.
#11 Matlock
Posted 06 July 2020 - 09:58 pm
:rotflmmfao: Understatement of the year. I was lucky enough to have a proper engineer, like Lee, teaching us Gas Engineering back in my apprenticeship days. We had a lathe, milling machine and welding kit in the college workshop and we were taught the basics as a bonus, it wasn't in the curriculum. As Pedro says, creating a bolt from a lump of steel seemed like magic at the time.
#12 Bjørge
  • 1,792 posts
Posted 07 July 2020 - 06:32 am
Impressive! I would like to have a shop like Henty's nearby...think I would come up with excuses to have parts made just to watch... 😎
#13 leehenty
  • 5,088 posts
Posted 07 July 2020 - 08:28 am
I can give fellow Carpedians lessons.
I run a project opening up a workshop in partnership with the local Mind branch called "Men's Shed"
I supplied the Lathe, miller and tooling down there. Aimed at men over 50. We have had an enforced shutdown due to Covid 19.
Tried to explain the principles of a dividing head to Cats. I grew up with it all. I was using a lathe at 10.
#14 TKH
Posted 07 July 2020 - 10:41 am
Wish there was a Lee Henty near me! Or that I had the skills and the tools. Mmmm wonder if there will be any night school classes for this opening soon......
#15 Studley Ramrod
  • 19,214 posts
Posted 07 July 2020 - 11:14 am
Check out https://menssheds.org.uk/ Keith.  There's one near you that does metalwork.
#16 Pedro
Pedro
  • 266 posts
Posted 07 July 2020 - 12:23 pm
I supplied the Lathe, miller and tooling down there. Aimed at men over 50. We have had an enforced shutdown due to Covid 19.Tried to explain the principles of a dividing head to Cats. I grew up with it all. I was using a lathe at 10.
I can only dream of an opportunity like that!
Edited by Pedro, 07 July 2020 - 12:28 pm.
#17 leehenty
  • 5,088 posts
Posted 07 July 2020 - 12:29 pm
This is a 90:1 rotary table with a dividing plate fitted. Lets you mill curved slots and quadrants when dividing plate isn't fitted or divide circles to make hex heads for example when it is fitted. I don't do the sums for this, too tedious. 90:1 tables are out there in the web.
Edited by leehenty, 07 July 2020 - 03:37 pm.
#18 dapleb
  • 18,117 posts
Posted 07 July 2020 - 02:12 pm
Yes please! When summat somewhat "normal" returns I would be very interested in that.
#19 catsbum
Posted 07 July 2020 - 03:51 pm
Hold my head in shame. About to order a new set so all will be good!
#20 PICARD
  • 1,744 posts
Posted 07 July 2020 - 05:23 pm
In the pub again then Lee?
Fell over at 90:1.!!
