* * - - - 1 votes
Loving My 'new' Tdm!
17 replies to this topic
#1 Navigator1946
Navigator1946
    sixtyniner
  • 69 posts
Posted 10 July 2020 - 03:03 pm
After three weeks, I'm really getting into my 'old' 08 TDM900. After loving a Honda Crosstourer for several years, I looked around for a replacement as the CT is getting too heavy - I knew it would eventually. I tried a Fazer, but found it too cramped, although I loved the engine. A friend suggested a TDM might be the answer, and so it proved. It's so easy to move around the garage, and so nimble on the road that I prefer riding the TDM now. I feel a little ashamed leaving the poor CT, but I'm sure we'll both get over it!
Cleaning the alloy wheels is a delight after the wire wheels of the big bike. I'm sure I'll get used to coping with a chain and I'm already seeing the advantages of a clutch after the dct 'box and shaft drive. I've already had the panels off to fit a sat nav mount (I never dared on the CT!) and I'm sure I can cope with most simple servicing work, so I will save on the running costs, although I'll need help with the tappets, when they're due.
Thanks for all your contributions to this site as you make life so much easier for those of us new to the TDM world.
2008 TDM900 in beautiful black.  Fender extender, after market Bullster touring screen, radiator guard, RM-G crash bars, 12V/USB socket, Oxford heated grips, Bagster tank cover, centre stand, E22 Givi panniers, standard exhausts. Beautiful Acerbis hand guards. <p>2015 Honda Crosstourer Highlander dct. Fabulous bike, but getting heavier as I age. The 9er is its replacement, eventually.
#2 leehenty
  • 5,090 posts
Posted 10 July 2020 - 03:11 pm
Shims not due till 24,000. We can help you do it.
#3 drewpy
  • 1,758 posts
Posted 10 July 2020 - 04:21 pm
Tappets, not heard that word in ages.
I think it was a 1600 ford crossflow which last had tappets to adjust
#4 MickC
MickC
  • 408 posts
Posted 10 July 2020 - 04:42 pm
Same here Drewpy those were the days.
#5 leehenty
  • 5,090 posts
Posted 10 July 2020 - 06:28 pm
Got a 550/4 in garage which has them. Why aren't bikes hydraulic now ? The Royal Enfield has the same parts they fit in modern Harley's, hydraulic no need to adjust them.
Edited by leehenty, 10 July 2020 - 06:33 pm.
#6 Snowbird
  • 1,359 posts
Posted 10 July 2020 - 06:34 pm
I do tappets fairly regularly, and adjust points most days, and people thing aircraft are hi-tech, not the little ones! Mostly magneto ignition and I'm the idiot that has to deal with them, there's no mapping a fuel injection system as it's all mechanical and constant flow (well dribble), most lawnmowers are more hi-tech.
#7 ramo
ramo
  • 1,179 posts
Posted 10 July 2020 - 08:03 pm
Evening  Navigator1946,
I have been there with the CT, great bike, just too  kin heavy, I still drop in the CT forum, I have never known anyone get rid of the CT other than the reason of being too heavy,
makes my Blackbird feel like a 250 to push around lol
anyway post a pic of your Bullster screen, is it the really big one, middle or a custom size? does it seem to work OK for you?
cheers steve
#8 leehenty
  • 5,090 posts
Posted 10 July 2020 - 08:33 pm
Don't aeroplanes have two magnetos ? I know Tiger Moths have two, with old fashioned switches. Turn one off after another check it keeps going.
#9 gautrek
gautrek
  • 71 posts
Posted 11 July 2020 - 07:36 am
I have got tappets on both my prewar bikes, plus proper screw adjusters.
#10 leehenty
  • 5,090 posts
Posted 11 July 2020 - 08:38 am
The Royal Enfield still has a tappet cover but no actual adjusters inside. If you put in fast high lift cams you have to go back to solid pushrods so it's handy.
#11 Pedro
Pedro
  • 266 posts
Posted 11 July 2020 - 09:44 am
Most early light aircraft have two magnetos. Preflight includes turning each one off and checking for a rpm drop. Archaic technology but to change it would need certification and approval and cost $$$
#12 gautrek
gautrek
  • 71 posts
Posted 11 July 2020 - 09:54 am
I love magnetos. They don't need another power supply. I had both of mine rebuilt and they work like new. Just clean the pick ups occasionally and set the points. Job done. They should last for 10'000s of miles now.
#13 Snowbird
  • 1,359 posts
Posted 11 July 2020 - 10:05 am
Most of the light aircraft run two mags, theres a few motorgliders with one on converted vw engines but they have to be inspected twice as often, electronic ignition is starting to happen but still very new, in the states they can run twin electronic units but here they still have to have one capable of running without external power, the slicks and bendix mags I deal with are so simple to sort out and don't fail in lightening strikes, the engines are not normally revved up and down like automotive engines and only rev to 2700 mostly so mags do fine, with constant speed props they can play with the throttle and keep the engine revs the same too as the pitch changes as the power increases.
Diesels started to appear but don't seem massively popular, the majority are still on lycoming or TCM avgas aircooled engines.
#14 James
James
  • 570 posts
Posted 11 July 2020 - 12:01 pm
Hmmm, tappets. It’s nice to have something to adjust  :)
My XL600R has screws type tappets.
The Buell has hydraulic ones and pushrods and a duplex chain primary drive. Old tech  :good:
84 Honda XL600R  :)
04 TDM900  :good:
21 KTM 790 Adventure  ;)
#15 Navigator1946
Navigator1946
    sixtyniner
  • 69 posts
Posted 11 July 2020 - 09:35 pm
Ramo, I've seen your request for a photo tomorrow at Ollerton. I'm sure Lee will oblige. It's a lovely looking screen but a bit too low to keep the wind off, so I've just fitted a deflector above it. Not sure about the look - its as tall as
a block of flats! - but it certainly improves the airflow. I'll know more after a motorway ride down tomorrow.
#16 Bjørge
  • 1,792 posts
Posted 12 July 2020 - 08:04 am
...is this the reason you will be a little late? Increased drag? 😁
#17 Studley Ramrod
  • 19,214 posts
Posted 12 July 2020 - 11:27 am
Didn't look too bad imho Martin. :good:
#18 drewpy
  • 1,758 posts
Posted 12 July 2020 - 12:51 pm
I thought tappets were the mushroom things that go between the cam and the pushrods which is adjusted via the rocker arms above?
Did the Morini 350/500 Heron head engines have tappets?
