Hi
I have a 2000 registered TDM 850 with 27K on the clock which has a problem I am really hoping someone can help me with.
It started as a rapid knocking sound at around 2500 - 3000 rpm which sounded like it came from the top end of the engines (although this is hard to identify). Along with the noise was engine hesitation and short fluctuations in rpm even though the throttle was steady making it very difficult to hold a steady 30 mph around town unless you dropped a gear to rev it higher.
The bike went back into the garage I bought it off and they stripped the engine, replaced the Cam Chain, Shells, Big ends, Coils and Emulsion tubes but after rebuilding the engine the noise is just the same. There was no evidence of any bearing failure or metal in the oil and the garage say they could not find any particular wear on other components.
Below 2500 or above 3000 rpm the bike appears to be fine and the noise is either not noticeable or not there.
Any help would be appreciated as all my local contacts are baffled.
