Morning (UK) all,
Can someone please tell me how long the plug spanner is in your toolkit?
My bike didn't come with a kit and I need to change the plugs but none of my plug spanners work ok.
One is too wide and the other too short.
Arse.
I can get 2 lengths: 285mm or 160mm
http://www.bitzforbi...p...&BikeID=441
(if anyone's interested, these fellas are a lot cheaper than that German site I found mentioned here)
Which one would be best?
Thanks as usual,
GC
850 Mk1 plug spanner length
Started by
GC1972
, May 13 2008 09:20 am
3 replies to this topic
Posted 13 May 2008 - 09:20 am
This bit's just so witty it hurts.
Posted 13 May 2008 - 01:06 pm
QUOTE(GC1972 @ Tue 13th May 2008, 10:05 AM) <{POST_SNAPBACK}>
Morning (UK) all,
Arse.
Thanks as usual,
GC
Arse.
Thanks as usual,
GC
I don't have a plug spanner in mine but I use a 19mm (x 64mm long) socket, it's too big but does the trick; with an extender which makes the two 120mm long in total... I need to get the radiator off either way - don't know if this helps atall atall
Edited by Ruairi, 13 May 2008 - 01:07 pm.
"You only have one - You may as well enjoy it"
Rory Horan - Live/Recording/Broadcast Engineer
Posted 13 May 2008 - 01:16 pm
QUOTE(Ruairi @ Tue 13th May 2008, 01:51 PM) <{POST_SNAPBACK}>
Top man; -Thanks.
Posted 13 May 2008 - 08:42 pm
the plug spanner i use is 100mm, its one i had from another bike (poss the xj6) which i've cut down and drilled a hole in the top so i can get a allen key / stubby screw driver in for leaverage.
i can do both the plugs, without taking the rad off, nice
jake
jake
1991 H reg, in midnight black, dinky number plate, laser pro stock cans, rattle in the collector box, set of bent handle bars and 2 wheels, with a loud lump in between ; )
i used to be a brain surgeon until i moved to rocket science
