Daves Ignition Goes Off When Riding
Posted 28 May 2017 - 05:57 pm
The digital display goes completely out, leading to sudden enjun braking and sharted pants!!
I did wonder if it was a side stand switch or summat but this doesn't turn the dash off.
So I'm guessing ignition barrel is plopped but any other suggestions before I search for a replacement?
Posted 28 May 2017 - 09:43 pm
I'm just back from a highland tour (Mini one) with my mate on his Ducrapi Multiwhatsist and it did the same thing! sometime knocking the instrument panel off and sometimes not, Bloody scary on a nip and tuck overtake on highland roads, so we tied a cable tie around the spring on the the sidestand to the sidestand to tension it a bit in case it was sagging going over bumps, it was worst between Ballachulish and Oban and a couple of times after leaving oban, so we stopped at Lochgilphead and done the fix, and it never missed a beat to Moffat
Posted 28 May 2017 - 09:57 pm
Safety cut out switch (Big Red Button) playing up ?
Posted 29 May 2017 - 03:49 am
Ahh big red button. Will give it pokey prod SR ta.
With enjun not running, I cycled ignition on/off a number of times and noticed once in about 10 goes turning on the ignition is not activating the dash/ignition.
Posted 29 May 2017 - 04:43 am
Sounds like a dodgy ignition switch to me. Might be worth giving it a good squirt of electrickery contact cleaner down the key hole to flush out any debris. Common thing on Moto Guzzi apparently.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy, Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators Currently not fitted - PC3, Remus Revolutions.
Posted 29 May 2017 - 07:54 am
Also someone had a problem with there being play atwix the internal barrel and external sleeve what caused similar symptoms to mine which looked easily fixable.
Posted 29 May 2017 - 10:34 am
Noticed that it had no protective boot that I had seen elsewhere, so made wan ...still working fine. Attached back on bike ...and .... Noubt. Dont work at all now. At least its now consistent!!!
Posted 29 May 2017 - 12:11 pm
Posted 29 May 2017 - 12:46 pm
Oh dear daps it's frustrating innit, best have a bit of cake matey
Posted 29 May 2017 - 01:10 pm
Posted 29 May 2017 - 01:41 pm
Maybe look in Christmas cake box for a switch then
Posted 01 June 2017 - 10:02 pm
My mates Multiwhatsit had a split in the sidestand switch body and was full of water when he investigated on Monday, and said it looked like a stone had impacted it to cause the damage, the new switch arrived today, so should be good for Sunday
Posted 02 June 2017 - 12:07 pm
Has Alan bought a multiwoopsit then Jono
Posted 02 June 2017 - 09:38 pm
Yeah had it since last year
Posted 03 June 2017 - 03:56 pm
Thanks for the help. :-*
