No Auxiliar And Tail Light
5 replies to this topic
#1 josepgoncalves
josepgoncalves
  • 40 posts
Posted 17 September 2019 - 09:43 am
Hi there
Facing a problem in my bike. I have no front auxiliary and tail light. I assume fuse is OK because they do work when I set the Ignition to 'Parking', but with ignition ON I cannot get them to work.
Thanks for any advice,
José
#2 velf2003
velf2003
  • 51 posts
Posted 17 September 2019 - 12:48 pm
How are the non-working lights powered? Directly on the battery? By a fuse/relay? Any other possibility?
#3 josepgoncalves
josepgoncalves
  • 40 posts
Posted 17 September 2019 - 12:52 pm
It's the original front presence light and the tail light. They work with the ignition on 'Parking' but not with ignition 'On'.
#4 velf2003
velf2003
  • 51 posts
Posted 17 September 2019 - 12:56 pm
Is the rear brake light work? Is the problem with the non-function lights  a new problem, or did they never work while you had  the bike
Come to think of it... isn`t the 2002 model with a light switch on the left handlebar?  If so, could there be a solution to the problem?
#5 josepgoncalves
josepgoncalves
  • 40 posts
Posted 17 September 2019 - 01:10 pm
The rear brake light does work. I do have a switch on the right handlebar. The panel light does work, but not small light on front neither on the tail.
#6 drewpy
  • 1,758 posts
Posted 17 September 2019 - 01:14 pm
parking light is a different circuit I think as it just powers those lights.
just recheck the fuses by pulling out and cleaning, then trace the live feed to find any break in the circuit
