hi people !
Ihave a problem with my tdm900 , i love the motorcycle very much and a month ago i drove in the rain then a day later i could not start it - no spark in the plugs and no starting .
in the screen i see arorr 11,15 please help ,what can i do?
Not Starting And I'm About To Cray...
Started by
sniper123
, Apr 06 2020 06:11 pm
1 reply to this topic
Posted 06 April 2020 - 06:11 pm
Posted 06 April 2020 - 06:37 pm
Error 11 is cam position sensor, 15, is throttle position sensor, check your plugs and connectors under fuel tank.
Also may I direct you to JBX TDM website, it has manuals on there.
Edited by leehenty, 06 April 2020 - 06:34 pm.
