Posted 12 September 2020 - 06:17 pm
Oiler Mk2 is built using same relay timer to operate a cheap diesel heater injection pump.
This pump is rated 1/60 ml per stroke. Or on a 0.8mm welding liner nib one drop exactly. This is a solenoid pump so it needs pulsed power. Just a quick on off for a stroke. I set the timer to close relay for 0.4 sec every 4 mins.
This Mk2 version means no pwm controller mo motor or peristaltic pump. They are sealed and designed to live under a motorhome. They cost £10.95 from ebay. You want a 2-5kw heater pump..
To increase flow reduce time between the pulses or increase time to reduce flow.
The pump does not Syphon through as a spring holds the needle valve shut when not operating.
Edited by leehenty, 12 September 2020 - 06:19 pm.
