Givi E22 Opinions Sought
#21
Posted 01 June 2018 - 12:19 pm
Looks like I'd need to move the rear indicators to fit the PL347 fitting kit.
Easy job?
Thanks for any advice
#22
Posted 01 June 2018 - 04:07 pm
you dont have to move the indicators
#23
Posted 01 June 2018 - 04:55 pm
#24
Posted 01 June 2018 - 05:45 pm
PL347
Specific pannier holder for MONOKEY®, RETRO FIT side cases
maximum load allowed 3 kg / it is necessary to move the indicators from their original position
#25
Posted 01 June 2018 - 06:59 pm
You dont need to move the indicators unless you prefer.
Had the PL rack on my 9r and left the indicators where they are.
Edited by dablik, 01 June 2018 - 06:59 pm.
#26
Posted 01 June 2018 - 07:34 pm
Looks like I do after all according to Givi website - quote
PL347
It all depends on the size of your cases.
With the small E21 or E22 and so, there is no need.
#27
Posted 01 June 2018 - 08:04 pm
Or do I leave this off if only using the e22 cases?
#28
Posted 01 June 2018 - 10:06 pm
IIRC you can fit the cross-bar at a different angle to go under the rear mudguard rather than thru' it. There's an old thread with pix somewhere here. Don't leave it off.
I can't be sure since mine were already fitted thru' the holes by the previous owner.
Don't lose the brackets & bits for mounting the indicators - they can't be replaced should you need them.
#29
Posted 01 June 2018 - 10:14 pm
Joe the support bar needs to be in place, it will fit without going through the indicator holes, recall mine was angled up under the seat and put a cable tie around it..
#30
Posted 01 June 2018 - 10:28 pm
This is the way to go!
On the other hand Joe, don't worry to much about remounting the indicator lights.
Take the hex bolt, bracket, two inox washers and put them in the most forward place on the wing.
I've used loctite 639 between every item and it stays secure and won't move.
Just lengthen the wires for the light by soldering them and use shrink tubes and self amalgamating tape.
Done it last week with my wife's bike. Less then a hour work, with cake and beer
#31
Posted 01 June 2018 - 10:34 pm
I'll give it a go.
Joe
Edited by Joe90, 01 June 2018 - 10:37 pm.
#32
Posted 02 June 2018 - 08:36 am
just flip the bracket under the rear mudguard, jobs a good en
#33
Posted 02 June 2018 - 09:09 am
#34
Posted 01 October 2018 - 02:31 pm
so anyone use them, or better stihl has anyone used the older E21's and upgraded to the newer E22's and have an opinion please?
ok so that was a swift decision on my part! Just bought a brand new set of Givi E21's. I deliberated over buying the newer E22's but decided i prefer the look/style of the older panniers. tank yew all kindly fer contributing to the process!
#35
Posted 01 October 2018 - 02:45 pm
#36
Posted 01 October 2018 - 04:02 pm
#37
Posted 01 October 2018 - 09:10 pm
Can I ask where you got yours from?
pricey enuf Joe but i didn't want to wait any longer for winter deals incase they became unavailable.
https://www.ebay.co....ZgAAOSwpTJbsQD0
#38
Posted 02 October 2018 - 10:11 am
Cheers.
#39
Posted 05 October 2018 - 03:43 pm
they arrived today. brand new and perfect. the molding date stamp inside each pannier states they were produced June 2013 so have obviously bin sat around new and unused fer a few years. i'm happy.
#40
Posted 05 October 2018 - 09:52 pm
When you use them, make sure you really do close the top lid and lock it shut. It is easy, if you do not pay attention, to remove the key - thinking the top is locked - without the lid being secured.
After losing a camera and a few other bits from this error I now pull on the handles to check the top is shut properly.
