A Little Challenge.....
28 replies to this topic
#1 Snowbird
  • 1,361 posts
Posted 09 September 2023 - 01:41 pm
Picked up an outboard motor thursday on a bit (huge) of a gamble, it was advertised as for spares and stated that the cylinder block was knackered so no issues with the deal, I recon I'm gonna have a wee bit of a challenge but going to have a bloody good go at rebuilding the block (with a lot of help from Pete the welder at work).
When I got it home I hooked up the fuel tank and gave the primer bulb a few squeezes and tugged on the pull cord and away it went sweet as a nut so has to be worth a go at saving, it's a honda BF6B with the throttle stop removed to make it an 8HP, it's the same motor other than the restriction.
Attached File  20230907_194310.jpg   210.7KB   0 downloads
Attached File  20230907_194316.jpg   126.29KB   0 downloads
The crank rods and pistons look like they've barely run, main bearings look immaculate.
Attached File  20230908_142742.jpg   118.95KB   0 downloads
Wish me luck....
The clean up process so far, will be better when I get into the blasting cabinet at work.
Attached File  20230909_140904.jpg   126.03KB   0 downloads
Attached File  20230909_140911.jpg   151.51KB   0 downloads
Edited by Snowbird, 09 September 2023 - 01:44 pm.
#2 Catteeclan
  • 2,448 posts
Posted 09 September 2023 - 02:10 pm
The other good thing is it doesn't have to be to pretty as it's only got to hold water. Interested to see how Pete will tackle it.
My old boss would have called it monkey metal. {crap).
#3 Snowbird
  • 1,361 posts
Posted 09 September 2023 - 02:56 pm
Being honda I'm hoping it's good aluminium under there somewhere, the corrosion is down to salt water use.
#4 dapleb
  • 18,122 posts
Posted 09 September 2023 - 04:18 pm
Pistonias look
Bootiful....the rest not so much. But ewe is already up if it were fur spares. ♪⁠┌⁠|⁠∵⁠|⁠┘⁠♪
#5 Catteeclan
  • 2,448 posts
Posted 09 September 2023 - 07:10 pm
Good point
#6 dablik
  • 10,762 posts
Posted 10 September 2023 - 08:23 am
Fook me Dave, the mice been at that then, so i presume you hope to reweld that lot, would it mean having to cut away to good metal 1st..
#7 Snowbird
  • 1,361 posts
Posted 10 September 2023 - 09:47 am
I don't know about cutting away good metal, gotta find good metal first.
I'm hoping to keep most welding to the water jacket area to minimise distortion in the block itself.
#8 dablik
  • 10,762 posts
Posted 11 September 2023 - 06:49 am
Good luck matey hope it works out  :good:
#9 Snowbird
  • 1,361 posts
Posted 11 September 2023 - 05:29 pm
The metal looks better now it's been blasted cleaner, looks like it should weld ok.
Attached File  20230911_151601.jpg   368.97KB   0 downloads
Attached File  20230911_151625.jpg   452.9KB   0 downloads
And the donor material.
Attached File  20230911_160935.jpg   395.24KB   0 downloads
I also have a good piece of aluminium bar to make up a new threaded boss for the head bolt.
#10 dapleb
  • 18,122 posts
Posted 11 September 2023 - 07:11 pm
I think it's gonna make it!!
#11 dapleb
  • 18,122 posts
Posted 20 September 2023 - 06:07 pm
How cool. Looks noice!!
Cheaper than a yam boike gasket set?
#12 Snowbird
  • 1,361 posts
Posted 20 September 2023 - 06:41 pm
£60 just for the head gasket, luckily I only need a couple of other gaskets as most came off cleanly so a smear of non setting sealant on each side will keep costs down.
#13 Snowbird
  • 1,361 posts
Posted 20 September 2023 - 07:53 pm
My last post and pics seem to have buggered off so I'll re-post....
Didn't use the piston skirt in the end, had a couple of otherwise scrap magneto housings that had an almost perfect shape section so chopped them up.
Had a skim down today till the rest of the face just started to show signs of the cut then finished off with a sheet of emery on a surface table by hand.
Attached File  20230920_134240.jpg   313.73KB   0 downloads
Attached File  20230920_155252.jpg   418.86KB   0 downloads
That'll do it I recon, can consider buying the gaskets now.
Gonna give the water jacket another blast out then paint inside with a couple of coats of urethabond 104 as it sets rock hard and resists most things and will sort out any porous bits in the welds.
Got a couple of small bits in the exhaust ports to weld and dress then the head will be sorted.
Looks like I got myself a cheap outboard.
#14 Catteeclan
  • 2,448 posts
Posted 21 September 2023 - 05:59 am
That's some good work. :good:
#15 dablik
  • 10,762 posts
Posted 21 September 2023 - 08:20 am
Cor, well done Dave, that's a good salvage  :good: clever bassad  :P
#16 Snowbird
  • 1,361 posts
Posted 21 September 2023 - 03:57 pm
With a quick hone and a coat of paint and a drop of urethabond in the water jacket you'd never know.... :good:
Attached File  20230921_164640.jpg   372.17KB   0 downloads
Attached File  20230921_164702.jpg   312.88KB   0 downloads
Now to get the exhaust stud out of the head that I've broken.... :unsure2:
#17 dapleb
  • 18,122 posts
Posted 21 September 2023 - 06:01 pm
Boatiful
#18 Snowbird
  • 1,361 posts
Posted 22 September 2023 - 10:57 am
S'gettin there.
Attached File  20230922_112018.jpg   447.83KB   0 downloads
Got the broken stud drilled out and tapped this morning too so chuffed.
Also managed a bit of guvnors work but not much, far too busy.......
#19 ramo
ramo
  • 1,179 posts
Posted 22 September 2023 - 02:28 pm
Looks like a cracking job there mate :good:
#20 Studley Ramrod
  • 19,217 posts
Posted 22 September 2023 - 04:46 pm
Good skills SB 😎
