3Vd Fuel Tap
7 replies to this topic
#1 itchyfeet2
itchyfeet2
  • 123 posts
Posted 23 November 2020 - 08:37 pm
Hi all,
I dont have a picture but as you look at the 3vd fuel tap, the top hose goes into the tap via a right angled elbow. That complete elbow comes out of my fuel tap (obviously squirting fuel out).
Should this elbow have an 'o' ring to hold it in, should it be soldered or braised in or is it fooked.
Thanks to anyone wif da knowledge.
( I'm not a freeloader, I have subscribed to the forum,)
Edited by itchyfeet2, 23 November 2020 - 08:39 pm.
#2 Studley Ramrod
  • 19,202 posts
Posted 24 November 2020 - 06:22 am
Yes it should have an o ring.  It's the reserve feed and is a push fit.
#3 itchyfeet2
itchyfeet2
  • 123 posts
Posted 24 November 2020 - 07:40 am
Brilliant, thanks Studders.
Think that may explain the small black rubber like flakes in my carb bowl.
Hopefully that o ring is part of the tap rebuild kit.
cheers.
#4 Studley Ramrod
  • 19,202 posts
Posted 24 November 2020 - 12:12 pm
Not sure if it is in the kit or not tbh.  Seem to remember Dablik struggling to find the o ring a while ago.
#5 Studley Ramrod
  • 19,202 posts
Posted 24 November 2020 - 05:56 pm
Might be worth checking the fuel tap bolts that secure it to the frame.  If the bolts aren't original you might find one of the bolts can push on the reserve coupling, forcing it out of the tap.
#6 dablik
  • 10,735 posts
Posted 24 November 2020 - 06:01 pm
:wifgeni:  i could'nt find an o'ring to fit, it's tiny and i'm sure is square sided also, had repaired mine with Loctite chemical metal but that has'nt lasted, also bought a used replacement which went west also, now have a new one in-situ, another option is an electric pump but most people that fit one seem to revert back to mechanical..
#7 itchyfeet2
itchyfeet2
  • 123 posts
Posted 24 November 2020 - 07:10 pm
Thanks for the replies.
ive bought a second hand tap, hopefully has o ring. have you seen the cost of brand new? Bloomin hell.
#8 dablik
  • 10,735 posts
Posted 25 November 2020 - 06:04 pm
Sure, but after buying used which turned out to be shoite as well a new one would of been cheaper from the start, i would'nt be so comfortable riding around with a dodgy fuel tap leaking on a hot engine, you may get a decent used one but all are knocking on in years now..
