Extended Drain Carburetor 3Vd
14 replies to this topic
#1 JA83
JA83
  • 29 posts
Posted 05 July 2020 - 09:33 am
Hey
As many of you know, reaching the drain can be a b*h out in the field.
Mine has started too mix water with gasoline when turning the knob to reserv, so either condensation or a leaking lid.
Was playing with the tought around adding a nozzle on the carb and connect som hoses to a valve that easy reachable. Anyone that has done something similar?
#2 Studley Ramrod
  • 19,214 posts
Posted 05 July 2020 - 12:11 pm
Not that I'm aware of. Wouldn't it be easier to sort out the problem of getting water in the fuel ? Might just need a new seal/lid.
#3 drewpy
  • 1,758 posts
Posted 05 July 2020 - 06:32 pm
millers fuel additive holds the water in suspension and gets combusted use that in all my tanks as ethanol attracts water
#4 mh1848
mh1848
  • 507 posts
Posted 05 July 2020 - 08:23 pm
methylated spirit does a similar job and presume cheaper
#5 curlylegend
curlylegend
  • 308 posts
Posted 05 July 2020 - 09:37 pm
That appeals to me...  What kind of quantities do you add ?
#6 drewpy
  • 1,758 posts
Posted 06 July 2020 - 07:27 am
found this
https://autoexpert.c...n-the-fuel-tank
#7 leehenty
  • 5,091 posts
Posted 06 July 2020 - 10:22 am
Isn't adding yet more ethanol making it worse ?
Edited by leehenty, 06 July 2020 - 10:22 am.
#8 drewpy
  • 1,758 posts
Posted 06 July 2020 - 11:09 am
If your referring to my link, i think its the combination of the 3 chemicals that work together.
It did say you end up with EN0
#9 mh1848
mh1848
  • 507 posts
Posted 06 July 2020 - 10:20 pm
the piece i saw suggested a couple of tablespoons in a bike tankful
#10 drewpy
  • 1,758 posts
Posted 07 July 2020 - 06:14 am
can you find the article?
millars is £10 a pop
#11 curlylegend
curlylegend
  • 308 posts
Posted 07 July 2020 - 09:16 pm
So the water mixes with the ethanol, then that mixes with the petrol, then it all gets burned !!  Sound fine to me. I'll just carry on using 95 E5 from the supermarket.
I'm not allowed out in the rain anyway....
#12 drewpy
  • 1,758 posts
Posted 08 July 2020 - 07:06 am
it didn't say that.
water will separate from the ethanol.
The other chemicals combine to enable the water to be miscible and burn off in combustion
#13 dablik
  • 10,757 posts
Posted 08 July 2020 - 04:28 pm
Having just cleaned a rusty tank, again, i think i'll be using some of that millers, had used stabil before with good results over a winter lay up..
#14 curlylegend
curlylegend
  • 308 posts
Posted 08 July 2020 - 10:00 pm
it didn't say that.
Sorry, I'm maybe missing something, but after reading ......  " So, when you add water, ethanol and petrol, you get a miscible solution of all three liquids. "   .... I assumed that water, ethanol and petrol combine to give a combustible solution of all three ?   Obviously petrol being the largest part.
#15 wicklamulla
Posted 09 July 2020 - 06:44 am
i tink i got this,  basically all tree combined will enable the whole concoction to be burned off.
