Hand Guards Revisited. 850
Posted 03 February 2020 - 07:55 pm
Why oh why cant they be arsed to at least let you know which wire is what? Anyone in here with them, and how did you fit/wire them?
How do you add pics? If possible?
Posted 03 February 2020 - 08:14 pm
Hi KAL850,
Judging by the pictures there are only three wires per guard - a red, a black & a light blue, if these are Chinese it's pretty likely the red will be the negative, the black the positive and the light blue the earth or ground, I'm not an automotive electrician but dare say they will put a wiring diagram in with the goods to explain the wiring set up surely, they do look half decent though for the money, worth a punt.
Posted 03 February 2020 - 08:58 pm
Material: ABS
Led light: Blue for running, Yellow for turning signal
Color: Black
Placement on vehicle: left, right, front
Black line: positive pole
Red line: daytime light
Blue line: turn light
I would interpret line as cable
red cable - daytime running light, take feed foe this from a switched live, pref lights
blue cable - indicator, take feed for this positive feed to indicator
Black line as earth ?
just touch the black to negative on your/a battery, and then the blue and red in turn to the live, you will soon see what colour LED lights up
don't worry you won't hurt anything
Edited by ramo, 03 February 2020 - 09:02 pm.
Posted 03 February 2020 - 09:09 pm
There you go, said I wasn't an automotive electrician !
Posted 04 February 2020 - 11:28 am
LED's are diodes so if you connect up backwards, they just don't light as no current flows.
