Tdm900 Parts On Alternative Bikes
2 replies to this topic
#1 Malky900
Malky900
  • 8 posts
Posted 07 February 2020 - 12:42 am
Hi folks... Being new to having a TDM, I've been looking for some parts on eBay. If I search for TDM900 parts, they seem limited and sometimes expensive, however, there are other bikes that share some of the same parts, fzr1000, fjr1300, warrior...etc...I used the following parts website to locate the part and part number, this then displays the other bikes that it fits.. So, for example,I was needing a front brake disc, when I searched for TDM parts, it was £80-£100 for a pair... When I searched for fzr1000 discs, I got them for £55... It's worth a look
https://www.motorcyc...900-motorcycles
#2 leehenty
  • 5,088 posts
Posted 07 February 2020 - 09:10 am
thanks for this
#3 wicklamulla
Posted 07 February 2020 - 11:12 pm
handy.  good work man.
