Engine Mount Bolt Thread Pitch Sizes 850
9 replies to this topic
#1 dablik
  • 10,735 posts
Posted 16 February 2020 - 09:38 pm
Cant find me thread gauge anywhere in the house, sure it will turn up eventually.............so
Can anyone tell me pitch size of the M10 engine mount bolts please, pretty sure it's 1.25 pitch but need to verify as i'll have to buy a tap to clean up the threads, looks like they got gunked up a bit during vapour blasting and wont take a bolt without forcing it...
Will have to replace all the bolts as well as they are proper mullered, dont know how they were ever torqued correctly...
Edited by dablik, 16 February 2020 - 09:40 pm.
#2 leehenty
  • 5,080 posts
Posted 16 February 2020 - 09:43 pm
1.25, be careful the thread does not end up oversized or it will be prone to stripping.
If it does I have various length helicoils to fix it.
Edited by leehenty, 16 February 2020 - 10:44 pm.
#3 dablik
  • 10,735 posts
Posted 17 February 2020 - 01:28 pm
Cheers Lee, i'll give them another once over, i have some Helicoils but maybe M8 only...
#4 Studley Ramrod
  • 19,202 posts
Posted 17 February 2020 - 05:49 pm
I use my tap and die set to measure thread pitch, same pitched bolt will slot into same pitched tap. :)
#5 dablik
  • 10,735 posts
Posted 18 February 2020 - 08:33 am
No M10x1.25 tap though, suppose i could of used the M8..
Edited by dablik, 18 February 2020 - 08:34 am.
#6 leehenty
  • 5,080 posts
Posted 18 February 2020 - 05:37 pm
do it right, no bodgit and scarper, they ain't dear.
https://www.amazon.c...la-421981167243
#7 Snowbird
  • 1,349 posts
Posted 18 February 2020 - 06:45 pm
For oddball threads this place is useful.
https://www.tracytools.com/
#8 dablik
  • 10,735 posts
Posted 19 February 2020 - 08:40 am
Cheers for that, the full monty on that site...
#9 leehenty
  • 5,080 posts
Posted 19 February 2020 - 01:48 pm
+1 for Tracy Tools
#10 leehenty
  • 5,080 posts
Posted 19 February 2020 - 01:55 pm
Niner engine mount bolts are M12 x 1.25 same as sparkplug thread.
