Posted 13 February 2020 - 08:02 pm
you can unscrew them with a special tool, but they unscrew inwards pushing out the piston so you turn them clockwise.
Compressed air will be your friend but watch out for fingers and eyes.
Wrap tape around lobes of tool to protect the anodised finish in caps.
Laser tools 7244 about a tenner.
https://www.ebay.co....ASABEgKf-fD_BwE
Edited by leehenty, 13 February 2020 - 08:10 pm.
