4Tx Fuel Pump
11 replies to this topic
#1 chrisbee
chrisbee
  • 391 posts
Posted 15 July 2019 - 08:28 pm
I have just looked online for fuel pumps for the 4tx, and have found 2 completely different items..
can someone explain please??
TIA
Chris
#2 Rallyist
  • 3,250 posts
Posted 15 July 2019 - 08:50 pm
One electric and one vacuum operated, if when you turn your bike on and you hear a ticking you have the electric one.
#3 wicklamulla
Posted 15 July 2019 - 11:25 pm
Chris your TDM takes the electric one.
#4 drewpy
  • 1,753 posts
Posted 16 July 2019 - 08:28 am
I have an electric one for sale. it cost £80 from fuel performance early last year but the way it was positioned in the bike, it kept overheating and cutting out.
rather than having it sit there, you can have it cheap. the only caveat is I changed the electrical connection to the waterproof ones
#5 Bjørge
  • 1,791 posts
Posted 16 July 2019 - 08:39 am
The electric one looks very much alike the one I bought - just beware the extreme noise it makes. You can clearly hear it at 60MPH !!
#6 Studley Ramrod
  • 19,202 posts
Posted 16 July 2019 - 08:52 am
Yours is a leccy wan Chris.  It's not a TDM wan though, iirc it's off a Yamaha scooter, wanna them large cc scoots.  The original failed and all I could get at the time was the one I fitted.
#7 chrisbee
chrisbee
  • 391 posts
Posted 16 July 2019 - 09:31 am
Thanks for the replies,
it isn't for my bike..
It is for a mates bike, that had a breakdown, and has been perfect since.
It is also the cleanest TDM I have ever seen, and he loves it. We will be touring with this chap next year, so if it has a weak pump, it would be best to get it sorted.
Chris.
#8 MipeTDM
MipeTDM
  • 92 posts
Posted 16 July 2019 - 10:21 am
Hi,
Although the advert mentions for TDM etc, the electric pump you show seems to have 10mm connections. The TDM however needs 6 or 8 mm connections (original is 7mm I believe).
The pump you show is also available in an alternative variant with 6 mm connections. Recommend to look for one like that instead. I bought one from the UK off Ebay recently for my bike.
Indeed is is somewhat loud, but I tackled that largely with some rubber mounts (if not already fitted).
#9 ChrisG
  • 8,275 posts
Posted 16 July 2019 - 02:04 pm
Looks the same as the one I fitted to the wife's Diversion, it was really loud to begin with but quietened down a lot after a ride, I assume it was a bit of air in the pump causing it to be louder.  Have you checked yours isn't rattling against the frame?
#10 Bjørge
  • 1,791 posts
Posted 17 July 2019 - 08:48 am
Yup, rubber (bicycle inner tube) mount like yours. It's more like an extremely loud relay sound, too loud for my liking. Bought me a used Fazer(?) pump to replace it, not yet mounted.
#11 Studley Ramrod
  • 19,202 posts
Posted 17 July 2019 - 09:54 am
The leccy pump I had fail on me was terminal so not sure if yer mates breakdown was caused by a faulty pump, mighta been a dodgy pump connection or something else.
#12 chrisbee
chrisbee
  • 391 posts
Posted 17 July 2019 - 11:10 am
It must have been a dodgy pump connection..  The RAC man cleaned up the connectors, and it has run fine since.
