Posted 26 September 2022 - 11:37 am
I'd avoid the el cheapo chinese stuff if possible. I have used Excel machine tools for years. The kit lasts, the lathe came from them in 1996 and it's still running fine. Obviously it depends on your use and budget. I still run Dad's old Atlas that's probably older than me. It's been rebuilt a few times.
https://excelmachinetools.co.uk/
Edited by leehenty, 26 September 2022 - 11:53 am.
