Carburettor Nightmare.x
13 replies to this topic
#1 Russ3VD94
Russ3VD94
  • 4 posts
  • TDM model: 1994
Posted 05 March 2017 - 07:58 pm
OKAY, so newbie at tinkering. Took carbs off, tank off, fuel tap and now so many hoses I have no idea what I'm doing.
Can anyone direct me to a diagram of how how the hoses run please? I'm very visual, I now know that in future I should take pictures!
Ps I am not blowing kisses! Jeez, I miss pressed my phone! Lol
#2 Got1now
Got1now
  • 240 posts
Posted 05 March 2017 - 08:19 pm
Do you have a Haynes manual? Most of the toobs go back where they land. Not too much chance of getting anything mixed up though.
Studley Ramrod is the carb guru.
Where are you? Maybe someone local can assist......
#3 drewpy
  • 1,758 posts
Posted 05 March 2017 - 08:26 pm
there's yam manuals knocking around and they show all routing, cables, hoses etc
#4 Studley Ramrod
  • 19,213 posts
Posted 05 March 2017 - 09:54 pm
I've not seen a diagram showing routes for ALL the hoses for a mk1.  Might help if you could throw some pics up showing us what you need help with.
The Haynes manual should help you locate some of them, as will the mk1 parts fiche.
#5 Favs
  • 4,394 posts
Posted 06 March 2017 - 09:11 am
Can't help with yer carbs but,  -  Hello
#6 Russ3VD94
Russ3VD94
  • 4 posts
  • TDM model: 1994
Posted 06 March 2017 - 11:53 am
Thanks guys, I think I'm slowly getting there, I've got a diagram now, it's making much more sense! I used www.cmsnl.com, very very helpful
Oh and hello!
#7 Swarf
Swarf
  • 314 posts
Posted 06 March 2017 - 01:41 pm
Afternoon Russ, was talking to you last night about this on FB.
#8 g650xtdm
g650xtdm
  • 295 posts
Posted 07 March 2017 - 02:14 am
This is for a US/California model, but it may help:  http://www.cmsnl.com...slist/B-09.html
The parts fiche on boats.net is also helpful (http://www.boats.net...ETOR/parts.html  ):
#9 kiwitdmer
kiwitdmer
  • 22 posts
Posted 15 May 2019 - 08:44 am
Hi all, I have a similar problem. Pulled carbs off long time ago and currently refitting. There are two tee pieces, one is fuel in (with filter in the tee) and another beneath it, part # 43 in the first link above. It shows a pipe bending down, is this just a drain?
#10 Studley Ramrod
  • 19,213 posts
Posted 15 May 2019 - 08:55 am
Yes.
#11 kiwitdmer
kiwitdmer
  • 22 posts
Posted 15 May 2019 - 09:13 am
Thanks Studley, wasn't too sure as there is a drain off each bowl (smaller dia tube)
#12 Studley Ramrod
  • 19,213 posts
Posted 15 May 2019 - 06:17 pm
It might be a breather/drain-off.
#13 kiwitdmer
kiwitdmer
  • 22 posts
Posted 03 June 2019 - 10:26 am
Hi again, another question re the carbs. Got bike running today using tank hanging above gravity feeding direct to carb, all good. But when I opened up the throttle while running only the right hand slide opened/fluttered. Assume they should both open and be in sync?
Is this likely to be due to a damaged or incorrectly fitted diaphram?
Had a bit of a mission to get it reassembled, not helped by the fact that it had all been apart for a few years.
#14 Studley Ramrod
  • 19,213 posts
Posted 03 June 2019 - 04:51 pm
It could be.  With the engine stopped, push the black slides up in turn, there should be slight resistance.
