850 3Vd Used Gearbox
6 replies to this topic
#1 Phracker
Phracker
  • 19 posts
Posted 29 May 2019 - 07:46 pm
I've finally stripped it down my engine to find that 3rd's dogs are all rounded and the pockets of 4th have some wear too. Bike had issues with 3rd since the day I bought it, so this all kinda makes sense now.
Would anyone trust buying a high mileage used gearbox? I'm wondering if I buy a swap if it will likely fail the same way. Mine only had 22000km on it and was already a problem.
#2 dapleb
  • 18,118 posts
Posted 29 May 2019 - 08:05 pm
Best to spect it first hey, else get a later box.
#3 dablik
  • 10,754 posts
Posted 30 May 2019 - 07:19 am
Taking a chance with any 2nd hand parts i guess unless you can look 1st, a mk2 box can replace the mk1 and i've read elsewhere from 96 98 or later the better so up to 2001 which is the year i bagged one from.
Edited by dablik, 30 May 2019 - 03:00 pm.
#4 Studley Ramrod
  • 19,214 posts
Posted 30 May 2019 - 08:44 am
I wouldn't trust a replacement mk1 gearbox, later mk2 and mk2a wans are much better quality.  The TRX850 gearbox will also work although it does have a slightly higher 1st gear.
#5 Phracker
Phracker
  • 19 posts
Posted 02 June 2019 - 04:38 am
Huge thanks! I was unsure if I could swap a gearbox from a 4TX or not.
I was eyeballing 3VD bits on ebay, but reluctant to pull the trigger on buying. I'll switch my search over to 4TX stuff.
A 270 crank would be nice :)
Also, here is what I found.
https://www.dropbox....dwear.png?raw=1
https://www.dropbox....hwear.png?raw=1
#6 Studley Ramrod
  • 19,214 posts
Posted 02 June 2019 - 05:20 pm
Yeah, I reckon it's the 4th gear that causes the wear to the 3rd gear dog, maybe a poor design.  Later gearboxes seem sharper edged.
#7 dablik
  • 10,754 posts
Posted 02 June 2019 - 05:25 pm
Dont think you can stick a 270 crank innit Phracker, surely you would need the mk2 camshafts as well !
