Will A 160/70 17 Rear Tyre Fit?
13 replies to this topic
#1 Mender
Mender
  • 50 posts
Posted 02 June 2019 - 10:21 pm
I have a new BT023 tyre 160/70 17,  does anyone know if it will fit my 2002 TDM900.
#2 TDM4ever
TDM4ever
  • 302 posts
Posted 03 June 2019 - 07:43 am
The standard tire is a 60-profile, so a 70-profile will add 16 mm to the height of the tire.
It will probably fit, but better check clearance...
Edited by TDM4ever, 03 June 2019 - 07:44 am.
#3 Atesz792
Atesz792
  • 65 posts
Posted 20 June 2019 - 09:13 pm
Well... did it fit?
Member from Hungary, riding an '02 9er.
#4 Mender
Mender
  • 50 posts
Posted 13 April 2020 - 02:25 pm
Well it fitted but looked a bit odd so I'm back to the standard size now!
#5 dandywarhol
Posted 14 April 2020 - 01:41 pm
It will but only 8mm to the ride height  :pimp:
#6 TDM4ever
TDM4ever
  • 302 posts
Posted 18 April 2020 - 07:27 pm
Ehhh..? Please explain.
#7 steve27bha
  • 784 posts
Posted 18 April 2020 - 09:00 pm
The back end would be raised 16mm,the front stays at the same height , so the difference in the middle of the bike is the average, 8mm.
At least, that's what I think DWH means.
The raise at the back will mean the handling will be different. Effectively the steering head angle will be steeper and the trail decreased. This should have a noticeable effect on the handling, turn-in and possibly the stability.
I raised the back of my VFR750 by 10mm by shimming the top shock mount, and that had a noticeable effect, quickening the steering.
The higher back end will also affect the operation of the centre stand (making raising the bike easier) and the angle of the bike on the side stand (leaning it more).
Edited by steve27bha, 18 April 2020 - 09:01 pm.
#8 TDM4ever
TDM4ever
  • 302 posts
Posted 19 April 2020 - 08:05 am
Ok, I thought he meant only 8 mm at the back  :good:
Edited by TDM4ever, 19 April 2020 - 08:06 am.
#9 fixitsan
  • 4,676 posts
Posted 19 April 2020 - 11:50 am
I took it to mean that the tyre has a 16mm greater diameter, but as the ride height is fixed by the spindle being only halfway up the tyre, the ride height is increased by the radius amount, not the diameter amount
#10 Norwegian
Norwegian
  • 162 posts
Posted 19 April 2020 - 11:59 am
So did I, but then I checked it in a tire calculator, and the diameter is actually increased with 32 mm, or 5.1 %, going from 60 to 70 profile. Radius then 16 mm, equalled to 8 mm between front and rear.
Edited by Norwegian, 19 April 2020 - 12:00 pm.
#11 dandywarhol
Posted 19 April 2020 - 05:29 pm
Sorry, senior moment - it does add 16mm to the ride height  :hide:  :sorry:  :pimp:
#12 wicklamulla
Posted 19 April 2020 - 11:28 pm
i thought it would be 8mm too.
#13 fixitsan
  • 4,676 posts
Posted 20 April 2020 - 09:07 am
I probably should have checked too...... That is a bit of a jump up in size  for sure
#14 dandywarhol
Posted 20 April 2020 - 09:27 am
The tyre carcase is 16mm lower on the profile from 160/70 to 160/60 so it will lower the bike by that amount
